Has anyone ever had any problems with this coil? I installed mine and it seems to missfire like crasy, and sputter under high boost. I had to take it out and reinstall my stock coil, everything was fine after that. Also, what coil wire are you guy's using with this also?
Weird, mine works ok. What ignition are you using Mike?
I am using the SR20DET motor, it has an external coil. Since we had to re-wire everything, I do not know how to re-incorporate the stock coil to work again, so I need a better coil to use than this MSD.
yeah the hvc msd works great, expensive but great
i use the blaster ss and car got leaner so was able to add more fuel and get better combustion. also got 15-20 more km on half tank of gas
i am saving for the digi 6 to replace my 6a and the street hvc
Buy at coil wire kit from most hod rod shops comes with the right boot. Thats what i did. it swas like 3.00-5.00
Larry Low
