Originally Posted by UNDRCOVR
Okay. I have finally gotten all of my other problems out of the way, now the tranny takes a giant sh*t on me. Tonight I was driving somewhat hard because I have been having problems since I raised the boost. I finally got all my hoses secured and they arent popping off anymore. Anyways, coming out of 3rd gear, I went to shift and all it does is grind. I had to limp home in 5th since it was the only gear I could find. I get home and I go to neutral(or so I thought) and when I let off the clutch it grinds.
From my searching, I have come up with a couple possibilities:
1. The bad mount is causing all these problems (crosses fingers)
2. The clutch tossed a spring
3. Internal tranny problems (With my luck, this is what it is)
My vote says it's #1. Solved for around $40 at a dealer.
You can VOR (Vehicle Off Road) order the part, and they
will expedite it for a 10-20% additional fee.
I had this happen to me on my '92. It was the worn mount.
My shift rod also got replaced because there was more slop
in the bushing where it connects to the transaxle strike rod
than I was willing to leave. That was another $50-60, IIRC.
I doubt *highly* it's an internal transaxle problem.
Peter
