Old 04-08-2004, 11:51 AM   #1 (permalink)
sr20 addict
getting out the old injectors....help
how and the hell do you the injectors out of the fuel rail do you need a speacil puller or something????? And do they need to be press fitted in once
you've got them out???? help me i don't wanna break them?? thanks
dave
White 93 SE-R
Mods:
JWT POP
JWT S3's
JWT PP & Disc
OBX Header
VRS 2.5 Cat-back
Eibach Springs on KYB AGX's
B&M SS
Hyperflex Kit
http://memimage.cardomain.net/member_img_a/574936_36_full.jpg[/img]
///M5 is offline   Reply With Quote
Old 04-08-2004, 11:55 AM   #2 (permalink)
No soup for you
Trader Rating: 30 (100%)
Re: getting out the old injectors....help
dave
You need to be very careful not to break off the top of the injectors. I put the rail into a vice, just snug, you don't want to bend anything. Lay a towel over the top of the injector. Take a pair of channel locks an grab the injector on the flats. twist the injector unil it spins in the rail, then start pulling up, while twisting. It should pop right out. Watch out for gas, as some is surely to come see you. Also, I take no responsibility for any damage of your injectors that might occur. Please use common sense and be as delicate as possible.
John
B12 turbo madness
424 whp / 328 ft. lbs
2440 lbs. w/ a full tank
B14 VE Hotness
244 whp / 228 ft. lbs
Old 04-08-2004, 12:39 PM   #3 (permalink)
I had a bitch of a time getting the 370's out of the BB fuel rail I had but eventually they came out. I used possibly a less advisable method. I used a large flat-headed screw driver/chisel type tool. My dad is a mechanic so it was a specialized tool not for injector removal but it looked handy. The pliers method also works. I also take no responsibility for injector harm during the removal process.
I also suggest replacing the screws that hold the caps on the injectors with hex headed ones. You won't have such a hard time getting them out next time. If there is a next time.
'97 SE-R with BB T25 setup, G20 ECU, E-Manage, Starion FMIC, SPEC 6 puck stage 3 clutch, D2 coilovers, fully shaved doors including side molding, Royal Sapphire Pearl (Toyota Supra) paint, Halo headlights, Aerogear vented hood, 98 Sentra Grille, Vis Extreme front bumper, Andy's Autosport rear bumper, and Kenwood Excellon CD player (Formerly Raser-X's car)
http://www.uwm.edu/~elh3/Pictures/20...rbocharger.jpg
Tomcat5678 is offline   Reply With Quote
Old 04-08-2004, 12:43 PM   #4 (permalink)
Import Tech.
Also spray some silicone lube ( or even WD-40 ) around them to make the seals slide better , turn them in the rail , that will help them come out , turn and pull ...
SHAWN
Ger-Brock Performance
Portland OR.
'98 Sentra SE.. Time Attack
'06 Pathfinder SE
'93 Infiniti G20 5spd.
My Nissan Site !!
Old 04-08-2004, 01:57 PM   #5 (permalink)
ClamSlut
Calum's Avatar
Approved vendor
Trader Rating: 24 (100%)
This is good advice!
calum@calumsult.com
Calum is online now   Reply With Quote
Old 04-08-2004, 02:09 PM   #6 (permalink)
NISSAN ADDICT
RYAN_S-14's Avatar
Trader Rating: 20 (100%)
a quote from zeroyon.com...
Removing the stock injectors can be tricky. Don't just try to pull the out from the top with a pair of pliars,
they will break. It's best if you apply pressure from the bottom and pull from the top at the same time.
The method pictured here (rubber mallot) is NOT the preferred method unless you don't care about the injectors.
RYAN_S-14
WWW.FLORIDASR20S.COM
RYAN_S-14 is offline   Reply With Quote
Old 04-08-2004, 02:45 PM   #7 (permalink)
I lika da turns
Just twist and pull. That's all I did. Takes a little work but you don't need any special tools. Guess it helped though that I was putting new ones in anyway though. Just make sure that you don't lose that little rubber insulator underneath the metal "hat" on top of the injector. I lost one and my damn dealer had to special order it.
Ben
'05 Subaru WRX STi
'93 SE-R Rocketsled (SOLD)
Drive it like you stole it (or at least try to before it breaks)
http://www.imagestation.com/picture/...1/fa5710dd.jpg
Cannibal is offline   Reply With Quote
Old 04-08-2004, 02:53 PM   #8 (permalink)
sleeper
I would tell how i did it on the car, but i broke two of them good thing i didn't need them.
Khiem
'05 Evo
'05 CBR 600RR
Old 04-08-2004, 03:05 PM   #9 (permalink)
the service manual says to push them out rather than pull them out. this worked for me after struggling for a while. I too replaced the screws with small allen head bolts from Lowes (they seem to have more metric hardware than Home depot) and they look better and are alot easier to get out than those soft phillips screws.
--Eric
RallyKid is offline   Reply With Quote
Old 04-08-2004, 03:40 PM   #10 (permalink)
sr20 addict
thanks for all the reply's i'll try and get those out tonight, i hope i don't break any...
