Old 04-09-2004, 11:54 AM   #1 (permalink)
SR20JET POWERED!!!
Drivability problem
I just swapped my hightport into my b14. And when i start it up, it might die, or go down to 500rpm, then i have to let it warm up because if i press the gas the car bogs and allmost stalls, and if i drive it before it totally warms, and i step on the gas it will bog and pop, and when i shift or push the clutch before i stop it dives down to 500 rpm. I set the timming to 15 degress, and the tps is at 4.35 thats the best i can get it too. I havent checked the temp sensor yet. And i cant set the idle, whenever i turn the screw it doesnt do a thing, and its not my egr because i have a jdm intake.
please help.
Xse-rX is offline   Reply With Quote
