Old 04-09-2004, 05:32 PM   #1 (permalink)
MYSPACE.COM/STREETARMOUR
Lowering springs or coilovers?? Which is better??
I have R1 coilovers and my B13 handles like $h!t. I blow out my front struts even when they are raisesd as high as they go. But the I don't know if lowering springs will handle any better... I need info......
2nd Runner
2nd Runner is offline   Reply With Quote
Old 04-09-2004, 06:24 PM   #2 (permalink)
Traitor in your midst
Re: Lowering springs or coilovers?? Which is better??
Get your car aligned first.
-Jim
SE-R Cup Hooligan
Jim #98NX is offline   Reply With Quote
Old 04-09-2004, 07:00 PM   #3 (permalink)
Import Tech.
It all depends on the spring rates, if your rates are high , then most struts wont be able to take the abuse , springs will do the same thing if the rates are high, most aftermarket springs are pretty soft though , look into a good rate spring for your coilovers and with a good strut you should be better , what do you have right now , spring rates? struts ?
SHAWN
Ger-Brock Performance
Portland OR.
'98 Sentra SE.. Time Attack
'06 Pathfinder SE
'93 Infiniti G20 5spd.
My Nissan Site !!
Old 04-10-2004, 12:58 AM   #4 (permalink)
The Genesis
both springs and coilovers have their pros and cons, but in general, coilovers are better
Old 04-10-2004, 01:18 AM   #5 (permalink)
Red line chaser
If your stock shocks are already blown, then I'd invest in a good set of coil overs. I'm going to be installing the Tein coil overs as soon as I get a lil more money. Almost there but not quite. I have GAB adjustables now with lowering springs and the ride is decent, but I can still bottom it out on occasion if I manage to find a good enough bump or high speed dip. My current set-up handles well enough for daily driving and spirited curvy road runs, just watch for the potholes and such.
You're not the first to complain about the ride quality of the R1 coil overs. A friend of mine has them and he either bottoms out like crazy or just ends up being too stiff for the roads he rides on. A shortened strut set-up will give you the ride quality you desire, the tightness in the corners, and the drop that every enthusiast looks for.
96 SE-R: SR20VE - bolt-ons
97 SE-R: GtiR - getting there - need $$$
03 Altima SE V6: alarm+remote start/Pioneer TV+DVD/MB Quart comps/US Amps TU-4360/Stinger blocks, Expert RCA's, and 0 gauge wiring/rest of system going in shortly
WickedSR20 is offline   Reply With Quote
Old 04-12-2004, 11:12 AM   #6 (permalink)
At the time I have new KYB non adjustable struts, and I got an alignment hours after installing them.
My turns when to crap! On the stock springs I could take a corner sharply and quickly now the rear kinda drags. My 1/4 mile launch is better but I'd rather have a good ride and my turns...
TIEN? I thought tien did not offer a coilover for the b13?
Thanks for all your input anymore is greatly appreciated...
Old 04-12-2004, 07:29 PM   #7 (permalink)
Need Money
Tein is coming out with a coilover sometime for the Classic. Dunno when though. Usually coilovers are better, especially full ones.
mal_tiempo is offline   Reply With Quote
Old 04-13-2004, 02:44 AM   #8 (permalink)
Captain Slow
2nd Runner
Give your R1's the float test. They're not worth keeping, no matter how good a damper set you put on them. Take a quick trip over to the Suspension & Brakes section of NissanForums.com, and take a quick look at the stickys up top. They won't give you specific brands (actually, they do, now that I think about it), but they'll tell you exactly what you need to be looking for, and what you need to avoid.
