Old 04-11-2004, 05:44 PM   #1 (permalink)
Daytime Running Light Module
Does anybody know where the daytime running light control module is? I'm having some problems with my headlights - only the passenger side works for both low & high beams but the daytime running lights on both sides work. Also when I flip on the low beams, the high beam indicator on the dash is turns on.
I posted a thread under NX2000 for this earlier and it was suggested that it could be the daytime running light control module, so I'm trying to check it now.
Thanks!
Pauley
pman_29 is offline   Reply With Quote
Old 04-11-2004, 06:25 PM   #2 (permalink)
my egg has speed holes
spnx's Avatar
Re: Daytime Running Light Module
You might try posting this in the Canada section, since US cars don't have DRL modules.
I don't know where it is offhand, since I've never had problems with it, but I am working on my NX2000 all day tomorrow, so if you don't have an answer by then, I'll find out and let you know.
James
spnx is offline   Reply With Quote
