Old 04-12-2004, 06:30 PM   #1 (permalink)
lack of sr20 owner
Adjusting Timing
Ok, Ive done this a few times on my car, or at least I thought I have but maybe just never got it into timing mode.
I did it the other day after I put my S4's in, and when I rotated the Dizzy to advance it, the idle went up. I have never noticed the idle going up while advancing timing before - but maybe it did and i was just too unaware?
so is it supposed to go up when advancing timing? like a couple hundred rpms? 850 - 1050?
and one last question - what do u guys w/ s4's have your timing set at, for the most performance? Im still at 15* *** the idle going up bothered me.
Thanks
Nate
2001 WS6
NateSR20 is offline   Reply With Quote
Old 04-12-2004, 06:34 PM   #2 (permalink)
Tired Greasemonkey
Re: Adjusting Timing
perhaps the rad fans came on while timing, thus causing the idle bump?
Old 04-12-2004, 07:06 PM   #3 (permalink)
lack of sr20 owner
my radiator fans are controlled by a switch, they dont work automatically any more.
There wasnt a bump - the idle went up and stayed up
Old 04-12-2004, 11:37 PM   #4 (permalink)
lack of sr20 owner
bump - anyone else? I want to advance my timing, but need to know if the idle going up is normal.
Old 04-13-2004, 12:20 PM   #5 (permalink)
lack of sr20 owner
bump again!
Old 04-14-2004, 01:09 PM   #6 (permalink)
Originally Posted by NateSR20
bump again!
i'm curious about this as well...when the idle climbs doe it mean that it is not in timing mode?
Stabone is offline   Reply With Quote
Old 04-14-2004, 01:19 PM   #7 (permalink)
fartin dust
Are the timing marks jumping around when ya look at them? If so you arn't in timing mode.
I used to be a noob but now I'm just a dumbass
www.m4exhaust.com
james vick is offline   Reply With Quote
Old 04-14-2004, 04:03 PM   #8 (permalink)
lack of sr20 owner
ok guys, I tried it again. This time the idle didnt go up, so Im thinking it had to do with me not getting into timing mode. right now I am at 17*, and my idle is a lopey 850 rpms. lopey because of s4's.
Timing marks were not jumping either time.
Old 04-14-2004, 05:05 PM   #9 (permalink)
JordanWhiteMusic.com
You probably weren't in timing mode. Did you follow the SE-R.net instructions?
Jordan - '94 Sentra LE
'07 Honda Fit Sport
www.myspace.com/jordanwhite
Storm88000 is offline   Reply With Quote
Old 04-14-2004, 11:26 PM   #10 (permalink)
"The world is yours"
i followed the se-r.net info and when i disconnected my tps sensor the idle would not go below 2000 rpm. is that right?
Wish list: Pulsar GTi-R, S-14 Silvia, and Skyline GT-R R33.
What I have: 91' B13 SE-R, 93' D21 Hardbody truck, 89' S13 240SX Coupe, and 95' Honda CBR600.
mr_cool_guy is offline   Reply With Quote
Old 04-14-2004, 11:33 PM   #11 (permalink)
fartin dust
Ya need to set the base idle. If the idle is above 1000 the ECU won't go into timing mode.
