Old 04-12-2004, 10:58 PM   #1 (permalink)
Is my Flywheel busted or my Clutch?? Help please
I was going down the highway about 70 MPH and I came up on an old person driving 45 MPH. I don't really remember but I know I was in 5th gear and and I didn't shift down and I thought I could pass, still in 5th gear at low RPMS and started to pass then CRUNCH!!!!!! I had to pull right over because it was making a grinding noise. (like flywheel teeth) Well I knew the clutch was going to go soon but I don't know what the prob might be now. I had it towed. when I start the car it runs and I push the clutch in and it goes into gear fine (no grinding) then when I let off the clutch the car dies?? Like something in the clutch "area" is caught. Bogs the engine down immediatly. What would cause this problem?? Thanks!
Nathan Klein
Nathan Klein
NX2000 (SR20DE) 5 Speed (150-160 RWH)
nathanklein is offline   Reply With Quote
Old 04-12-2004, 11:01 PM   #2 (permalink)
GT2835R
Re: Is my Flywheel busted or my Clutch?? Help please
The teeth on the flywheel are for the starter motor gear. Maybe a bolt backed out or something.
Rey Uy
99 SE-Limited
Old 04-12-2004, 11:17 PM   #3 (permalink)
Professor Dingbat
Drop the tranny if you can do it yourself. That looks like its the only way to find out. wont be that bad since you were planning on getting a new clutch anyway
Old 04-12-2004, 11:37 PM   #4 (permalink)
SE-R Searcher
drop the tranny and dont let it make the noise anymore. the grinding may be the leftovers of you clutch or Pressure plate that is grinding at your flywheel. hopefully you dont ruin your flywheel...
goneturbo is offline   Reply With Quote
Old 04-12-2004, 11:37 PM   #5 (permalink)
Yeah. I am going to buy a pro clutch on ebay. Stage 3
Old 04-12-2004, 11:54 PM   #6 (permalink)
SE-R Searcher
you may want to drop the tranny first and make sure that you are not going to need a flywheel as well. you can get clutch and flywheel combos for a cheaper rate than getting them seperate. or you may need to get a used stock flywheel from someone on the forum. I never heard of a pro clutch, you probably be best just getting the b15 disc and stock PP. it is probably a little cheaper that something on ebay, and you know you are getting good quality from the dealer.
Old 04-13-2004, 02:31 AM   #7 (permalink)
"I never heard of a pro clutch, you probably be best just getting the b15 disc and stock PP. "
I'm kindof new to nissan. Where can I get the this b15 disc and stock pp kit?
Old 04-13-2004, 06:45 AM   #8 (permalink)
I say I'm new to nissan yet I have gone completly through the GA16DE and now I am getting ready to go through the SR20DE! What the hell am I getting into??. Which is a more difficult? I know it was a pain in the ass to drop the tranny in the NX1600 but it was auto. Is it harder to drop the SR20 5 Speed Manual? Also how to I get the axles out??? Anyone in the kansas area that would take $100 and a 12 pack of beer to do my clutch job!!!
Old 04-13-2004, 10:43 AM   #9 (permalink)
dude it wouldn't be that hard. you axles should just pop out. plus if you do it then you will have the knowledge of being able to do it. just do it while drinkin that 12 pack itll be all good
Nismo5042 is offline   Reply With Quote
Old 04-13-2004, 10:57 AM   #10 (permalink)
315LB CLUB [][]-----[][]
i got a pretty new act stage 3 i wanna get rid of
'99 Sentra SE-L
'91 Sentra SE-R sold
FloridaSR20s
Thomas
sr20sentra91 is offline   Reply With Quote
Old 04-13-2004, 05:01 PM   #11 (permalink)
How much and why do you want to get rid of it??
Old 04-13-2004, 06:25 PM   #12 (permalink)
SE-R Searcher
ACT doesn't sell clutches in stages. For any car, you are going to want to match your clutch setup for the power of your engine. If you want an after maket setup then my suggestion is go with the clutchnet kits in the Group buy section. But if you only plan on making 170whp then you could spend less money and get a clutch from the dealer. It would be cheaper and could handle the power you plan on making. The b15 disc and standard Pressure plate may save you some money. If you plan on going turbo or nitrous then you may want to get an after maket setup. Warning, do not get a clutch setup that is too strong for your needs. It will make driving a nightmare. A 40% overstock Pressure plate, and a street disc will hold 300whp. you shouldn't need more than this, DO NOT GET A PUCK DISC unless your plans would be in the 400whp range. Last of all.....SEARCH. You will get better answers by searching than by posting....Remember that you may need some money for your flywheel if your current one has been damaged.
