Old 04-13-2004, 08:56 PM   #1 (permalink)
Crank Suggestions...
I took my crank out and it measured as follows...
Main Journals
Journal 1: 2.1640"
Journal 2: 2.1637"
Journal 3: 2.1638"
Journal 4: 2.1638"
Journal 5: 2.1637"
Journal 1 is the journal right next to the crank pulley...
Pin Journals
Pin 1: 1.8881"
Pin 2: 1.8881"
Pin 3: 1.8880"
Pin 4: 1.8880"
If you look at the specs of the main journal, it would entail that I would have a journal of grade #3. The smallest of the 4 grades available.
From the factory that crank was stampped with 1111 which means my pin journals have a grade of #1 from the factory, but after so many miles it is now barely a grade 2.
I ultimately want to use GTI-R main and conn rod bearings on this motor, what should I do?
A. Get this crank flashed and re-ground
B. Get a new OEM Nissan crank
C. Get a Jun crank.
I personally am leaning towards B and C. What do you think? Its an 8 web crank. Which USDM Nissan crank will fit? Where can I get a Jun crank? Does a S13/14/15 crank fit the U13 block?
Thanks
2001 White SE, SR20DE powered, 143 WHP (summer car)
1988 Mazda 323, 1.6 8-valve motor, 82 CHP (2004 winter beater - RIP)
1993 Nissan Pathfinder, VG30E (Tow Truck + Camping mobile, RIP)
1995 Infinity G20T, Manual + SR20DE (Wife's car)
1989 Mercedes Benz 190E (Pimpin' Winta' Beata'; RIP)
2006 VW Golf TDI (Can't beat 45 MPG!)
1994 Chevy Suburban Diesel (6.5L @ 18MPG @ 400 FT-LB or torque)
Kick Ass Matt is offline   Reply With Quote
Old 04-14-2004, 07:48 AM   #2 (permalink)
Seth's Dad
Re: Crank Suggestions...
I've got a good crank out of an engine if interested...
I can't answer your question though, sorry! What stampings are you looking for, perhaps the one I have will work?
Chris
2002 G20 Sport - Silver
2003 Olds Mini-Van - say wha????
1997 Corolla - 200+k!!! - Wifeys
MauiBlueGride is offline   Reply With Quote
Old 04-14-2004, 02:06 PM   #3 (permalink)
can you mic the journals and tell me what size they are?
Old 04-15-2004, 08:11 PM   #4 (permalink)
Getting desperate here...
