Old 04-14-2004, 03:56 AM   #1 (permalink)
Trader Rating: 36 (100%)
question re: re-using clutch disc
ok here's my story:
stock pressure plate with custom clutch disc, rated at 300ft lbs. put probably not even 1500 miles on this setup, dyno'd recently with 289 ft lbs of torque (running really rich so most likely will exceed the max rating for this clutch setup once i get it tuned right). anyhow, i'm looking @ upgrading my non-lsd transmission with the phantom grip, and might as well upgrade my clutch setup while the tranny is out. is it ok to re-use the disc and just change to a stiffer pressure plate, or should i replace it all? i do have clutch chatter, but not sure yet if it's from the clutch disc, or maybe i just have to re-adjust my rear motor mount. i rather buy a lightened flywheel than another clutch disc.
99 sentra se-l
t25 turbo part out:
http://www.sr20forum.com/forced-indu...isc-parts.html
iczer200sx is offline   Reply With Quote
Old 04-14-2004, 01:23 PM   #2 (permalink)
Rebuilding the W11:P
Re: question re: re-using clutch disc
I believe this won't work, as the Phantom Grip is inserted into the factory lsd assembly.
Why did the little girl walk around with a goldfish in her pocket?
So she could smell like the big girls.
se-riusb14 is offline   Reply With Quote
Old 04-14-2004, 01:47 PM   #3 (permalink)
it's inserted into the open diff of the non-lsd trannys as well.
Old 04-14-2004, 02:21 PM   #4 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
Your disc should be jsut fine with a new PP from ACT or whomever. I say use it.
BRent
Old 04-14-2004, 03:35 PM   #5 (permalink)
I never knew that
Old 04-14-2004, 03:38 PM   #6 (permalink)
Tired!
coach's Avatar
Yeah, they sell two different units, one for the stock lsd and one for the stock open diff tranny.
Brent
Old 04-14-2004, 03:49 PM   #7 (permalink)
owned by SE-Rs!
They are the same part for both trannys, 906-gold which coincidently also is used in VW golfs and lots of other cars. They are the same unit for open diff and vlsd diff, which I can get for you for $259 and springs for the upgrade for $25.50.
Nick McCollom
99 Infiniti G20
93 Nissan NX2000 14.027 @97.98 (N/A) I wish I had time and money again, this little car has sat for 2 years now. I do miss driving it bad. It will be back soon though faster than ever.
http://www.cincyclubclub.com/lilly/littlefamily.jpg
sakerocket1 is offline   Reply With Quote
