Old 05-08-2004, 09:12 PM   #1 (permalink)
help, just did det swap car wont turn over
checked fuel lines, swapped return/feed around still the same damn thing it wants to start and starts to sputter like it's going to, but doesnt, history on car (car ran like sh*t, eventually got worse, until wouldnt run at all, same symptoms i described, decided to go ahead and det swap, still the same sh*t, we have diff bb ecu, o2, maf and just a basic det swap, car still runs the same, did notice that the ground wire from the engine to the block was corroded to hell? change that?
anything please
nissanoholic is offline   Reply With Quote
Old 05-08-2004, 09:20 PM   #2 (permalink)
Super Sniper
Re: help, just did det swap car wont turn over
anything please
Yeah.. Change that... Have you verified that you have good fuel pressure?
Black B15 SE w/pp
White B15 SE w/pp
'92 NX2000 - sold
stuofsci02 is offline   Reply With Quote
Old 05-08-2004, 09:26 PM   #3 (permalink)
SE-R junky
Yes check fuel pressure, could be cloged fuel filter or bad fuel pump or relay.
shannon is offline   Reply With Quote
Old 05-08-2004, 09:32 PM   #4 (permalink)
Super Sniper
Oh yeah... Next pull the fuel pump fuse and then pull each of the spark plug wires off and hold it up to the VC one at a time, and check for good spark... It may be your ignition system..
Old 05-08-2004, 09:44 PM   #5 (permalink)
fuel pump is good, u can hear it on acc--when we got it to run for a breif second while it was dying out i pulled one of the wires away from the distributor and saw a spark would that be sufficient?
Old 05-08-2004, 09:45 PM   #6 (permalink)
also, how important is that block to frame ground?
Old 05-08-2004, 09:46 PM   #7 (permalink)
Super Sniper
You should check all the wires... Do this with the pump fuse pulled.. Then just have a pal turn the car over while you pull each one of the wires.. Pull from the spare plug, not the dist.
Old 05-08-2004, 09:47 PM   #8 (permalink)
Super Sniper
Take a set of jumper cables and ground your block to the frame... That should tell you if that is the problem..
Old 05-08-2004, 09:51 PM   #9 (permalink)
the spark issue doesnt make too much sence to me, i have a diff motor , new nology wires, new plugs, new dist cap, and i have an msd coil but that was with the car when i got it, could the prob be farther back from the coil wire, as i said i had the same prob with the last car, i'm going to try the jumper cable thing, also i regrounded the maf (spliced the center wire and grounded it on a braemetal part of the frame,
-seth
Old 05-08-2004, 09:52 PM   #10 (permalink)
-seth
i meant last motor in thaT CAR
Old 05-08-2004, 10:07 PM   #11 (permalink)
i did the engine ground thing, i did notice that my (i think ) coolant temperature senseor wire is ripped from the connector on the engine, thus not connected, it's a red connecter near my oil filter, would this make the probs i describe?
Old 05-08-2004, 10:09 PM   #12 (permalink)
Super Sniper
Possibly...I would re-solder that to the harness... Still pull the plug wires.. It takes 1 min to do, and then if you can confirm good ignition, and good fuel pressure, you should at least start and run..
Old 05-08-2004, 10:14 PM   #13 (permalink)
thanks alot, i'm praying that the cts does it, i mean, i've got head work hks cams, hks headgasket reworked t24, i should be fast plus weight reduction of a/c ps and lots of other sh*t, i'm so close--this is depressing@!
Old 05-09-2004, 12:39 AM   #14 (permalink)
GT2835R
How is the fuel filter, maybe it is really clogged.
Rey Uy
99 SE-Limited
Old 05-09-2004, 01:01 AM   #15 (permalink)
Super Sniper
Any word on this yet?
Old 05-09-2004, 11:06 AM   #16 (permalink)
new fuel filter, (300zx) new fuel pump too, it's something that was going bad over the period of a few months then ultimately got so bad the car wont turn over and run, swapped engine ecu, blah, blah, still same thing! any possible relays,?
Old 05-09-2004, 11:31 AM   #17 (permalink)
bad coil,? i have an msd but i dont know how old it is?
Old 05-09-2004, 03:58 PM   #18 (permalink)
coil checked, still will not turn over
