Old 05-09-2004, 12:10 AM   #1 (permalink)
SE-R SE-R SE-R
How many quarts for a Manuel SR20 Tranny?
I was reading some site it says to use 4 quarts of manual tranny fluid im like wtf never heard of a 4 banger using 4 quarts, anyone know what sr20 manual tranny takes?
y0ureviltwin is offline   Reply With Quote
Old 05-09-2004, 12:11 AM   #2 (permalink)
No D E T.
Trader Rating: 18 (100%)
Re: How many quarts for a Manuel SR20 Tranny?
4 whole quarts duuude. well maybe like 3.85092
edit whoa.. 1 minute after your post
Jonathan Schultz
1997 200SX SE-R U13 Swap
2005 Toyota Avalon Limited
honkeybizkit is offline   Reply With Quote
Old 05-09-2004, 12:14 AM   #3 (permalink)
SE-R SE-R SE-R
damn thats nuts and for redline, UCK 10 bucks a quart screw that
Old 05-09-2004, 12:29 AM   #4 (permalink)
GT2835R
http://www.myoilshop.com/AutoPrds.html
a little cheaper then 10 bucks
Rey Uy
99 SE-Limited
Old 05-09-2004, 12:41 AM   #5 (permalink)
No D E T.
also cheaper.. i think 10% off with this coupon code when you check out. 675421
i have shockproof light in my 200sx right now, good feel, but the car is pretty much stock. if i had turbo or was drag racing with slicks and heavy clutch (like my 92 will be) Id use Heavy.
Old 05-09-2004, 12:42 AM   #6 (permalink)
SE-R SE-R SE-R
yeah I found some places that sell it cheaper then 10 bucks but ouch, I can get service and non-synthetic oil all done for 25 bucks and being as poor as I am, I cant afford no 30-40 +20 bucks for service, my car is at 65k....
Old 05-09-2004, 12:50 AM   #7 (permalink)
Coropate greed hater
You don't change tranny fluid like you change the motor oil. Look at it as an expenditure that will give you really nice returns for at least the next 100,000 miles. Buy Redline MT-90 for your car. It is really good for N/A SE-Rs.
-The Usual Suspects
Old 05-09-2004, 12:53 AM   #8 (permalink)
No D E T.
whoa.. 20 for service, all you need is
-jack
-3/8" ratchet
-1/2" ratchet/breaker bar
-drain pan
-squeeze bottle with 3/8" or 1/2" diameter hose
i believe the fill plug is a 3/8" square plug, and the drain is 1/2" square.
you first jack the car up, put jackstand under for safety if you wish (i do). you should make sure the car is level as well, jack the rear up too. remove the fill hole FIRST! (this is important becasue if you drain it and then have a problem getting the fill plug out your screwed) then remove the drain plug an let it out into the pan. the plugs will be very tight, may need a breaker bar to assist you or a pipe for added leverage. after you let it drain for a long time, re install the drain plug and fill the tans with the new oil in a squeeze bottle with the hose so its easier.
bam you saved 20 bux and it only took a half hour of your time.
Old 05-09-2004, 12:55 AM   #9 (permalink)
SE-R SE-R SE-R
-jack
-3/8" ratchet
-drain pan
im a computer nerd, me dont have many tools, plus when it comes to cars im usually scratching my head so I usually let other people do the work and save myself from scratching my head. Plus I decided im the next year im going to trade this car in on a 240SX, 04 Cobra or any year Bullitt, or possibly a 93+ Rx7, looked onto insurance for Supra T and its horrible and im 30, but what I am meaning is I really dont want to spend alot of dough anymore on the car that im only going to keep at longest a year...
Old 05-09-2004, 12:56 AM   #10 (permalink)
GT2835R
^^thats a good simple way to put it, makes me wanna go out and do it right now haha.
Old 05-09-2004, 01:01 AM   #11 (permalink)
SE-R SE-R SE-R
I still cant believe this car takes 4 ouch ouch ouch my friend Celica takes one
Old 05-09-2004, 01:10 AM   #12 (permalink)
I guess I have another mini-writeup to do.
Old 05-09-2004, 01:18 AM   #13 (permalink)
SE-R SE-R SE-R
Well I am almost finished with the 60k service, all I have left to do is change the coolant, change the gear oil, change the belts, and get a new radiator cap and im done but as broke as I am I just cant afford redline not with 4 quarts =(
Old 05-09-2004, 01:29 AM   #14 (permalink)
not my president
i use amsoil 7 bucks a quart just as good as redline i think at least
1992 nx2000:White: Sold
Danielle Wilson 2/10/07
Old 05-09-2004, 12:20 PM   #15 (permalink)
Rob
a bud and i just put a tranny in my 92, and it took just about 4qts of shockproof
Old 05-09-2004, 12:47 PM   #16 (permalink)
Trader Rating: 15 (94%)
this shock proof sounds good, does any one use Gm syncromesh or anything similar,
Project Shift_Rebirth
Nyc Sr20PowerD is offline   Reply With Quote
Old 05-09-2004, 11:01 PM   #17 (permalink)
No D E T.
i used synchromesh in 3 honda boxes, because i think its similar to MTL, a little lighter weight. it seemed to do quite well in those. i wouldnt use it in a SR box, id stick with the redline gear oils, MT90, Shockproof Light or Heavy. Plus GM Synchromesh is about $10+ per quart i believe last lime i paid 11/qt and list is $12.something
Old 06-04-2004, 04:18 AM   #18 (permalink)
dho
Please help... will Royal Purple Synchromax work in the SR20 gearbox? Just bought some today but I'm getting second thoughts. (transmission's going in today at noon)
1992 SE-R w/ bolt-ons (HS CAI, Stillen 4-1 Header, Catco Hi-flow Cat, custom mandrel 2.5" exhaust w/ Dynomax Ultra-Flo muffler, JWT S3 cams, Hyperco Gen2 springs, AGX's, S.T. anti-sway bars, UR pulleys, FSTB, JWT Pressure Plate, JWT Metallic/Organic Clutch Disc, Prothane motor mounts, NX2K brakes, braided brake lines, B&M Short Shifter, etc...)
dho is offline   Reply With Quote
Old 06-04-2004, 10:37 AM   #19 (permalink)
No D E T.
well if you want to use royal purple you should be using their Max Gear 75w90... id take the synchromax back because its thinner. take it back and exchange if you can. synchro max is for manual gearboxes that take motor oil instead of gear oil, like old japanese tansmissions.
Old 06-04-2004, 12:49 PM   #20 (permalink)
mAd SE-R pOwAh
Four quarts is alot, but bear in mind that this is a transaxle. In my 350, the tranny takes 3 quarts of MT-90 and the diff takes 4 quarts of 75w-90 -- 7 quarts total.
Michael.
1995 M3 Coupe
2002 M3 Coupe
Michael-Dallas is offline   Reply With Quote
Powered by vBulletin&re
