Re: Vaccume Lines left over!!!!!
do you have a chiltons manual?
if you had egr on it i take it it was a usdm engine?
Blair Ellis has one for a usdm to convert when you take the egr off, vacume lines that should be on there are:
there are 3 underneath the TB (throttle body) one underneath one to the top and one in front. the one in the front of that little controler goes to the canister , the one on the bottom goes to the intake, the one on the top goes to the bottom of the TB then you have the one on the fuel return which goes to the top of the TB. those are the only fuel lines you should have. hope that helped.
