Old 05-09-2004, 08:23 PM   #1 (permalink)
JDM BOOST WHORE
SR20 91 SE-R's Avatar
A/c Over Heating
Why Dose My Car Over Heat When I Have The A/c Set On 4 But When Its On 1,2,3 Setting It Dosent?
SR20 91 SE-R is offline   Reply With Quote
Old 05-10-2004, 03:38 AM   #2 (permalink)
not my president
Re: A/c Over Heating
bump cause i have no clue
1992 nx2000:White: Sold
Danielle Wilson 2/10/07
Old 05-10-2004, 03:48 AM   #3 (permalink)
oh so LAZY
Will's Avatar
i dont see how that is possible, the compressor works just as hard. 1,2,and 3 are just resistors that keep less power from goin to the A/C fan. i dont see how that has to do with the car over heating. except maybe since the fan is sucking more cold on setting 4, the compressor has to stay engauged more, and the extra strain is causing it to over heat. i say check to see if the fan on the passenger side of the radiator is comming on when you turn on the air. good luck.
Click for My Car Pics
White '92 NX2000 All Stock.
Will is offline   Reply With Quote
Old 05-10-2004, 04:30 AM   #4 (permalink)
not my president
i was thinkin the same thing i guess its haunted
Old 05-10-2004, 01:09 PM   #5 (permalink)
JDM BOOST WHORE
yeah they both work fine. it wierd why its doing this. all day on 1,2,and 3 it works ine just that 4th setting.
Old 05-10-2004, 04:12 PM   #6 (permalink)
I like the boost!
The compressor is variable as are most Nissan compressors. On the 4 setting it works harder (Compresses further). creating cooler air and more heat in the condenser. Trust me on this one. I've done a lot of research into Nissan A/C.
turboAZ2 is offline   Reply With Quote
Old 05-11-2004, 01:44 PM   #7 (permalink)
JDM BOOST WHORE
so is there anything i can do about this problem or not? thanks for that info
Old 05-11-2004, 01:53 PM   #8 (permalink)
rollin 4 deep with JoeD
Re-bleed the head, bigger radiator, water wetter or Royal Purple Ice, better fans, etc...
Frank Orozco
cnynracer1 is offline   Reply With Quote
