Old 05-10-2004, 11:10 AM   #1 (permalink)
Car doesn't like to start///near stalling when disenguaging clutch
Im assuming this has something to do with the idle valve/cold start. When the car is warm it will start right up. When it is cold I need to feather the throttle and find the right spot to keep it running for a little bit. Also whenever I disenguage the the clutch, ie coming to a stop the car will want to die if I don't heel toe it constantly, unless I rev the engine down all the way and then disenguage. I assume it is that valve as I just replaced the engine but reused my manifolds(jdm swap) I also had the problem on the old engine. Back me up here.
88 300zx z31 turbo 280rwp @10 psi, 450 rwp and near 500 ftlbs. @16-18 psi(soon once this thing gets unbugged) 92 classic with suspension
Nickz31se-r is offline   Reply With Quote
Old 05-10-2004, 12:30 PM   #2 (permalink)
sleeper
Re: Car doesn't like to start///near stalling when disengauging clutch
check for vacuum leaks and readjust your idle.
Khiem
'05 Evo
'05 CBR 600RR
