Old 05-10-2004, 06:15 PM   #1 (permalink)
f@%k the yankees!
Pcv?
I Was Told To Get A New Pcv Valve. I Contacted Jgy And They Said That The All Of The Sr20 Pcvs Were The Same. I Got 1 From Auto Zone But It Looks Completely Different And It Doesnt Even Screw In. I Really Dont Think Its Gonna Fit So My Ques Is How Can You Test A Pvs To See If It Is Still Working??
TYPEILL is offline   Reply With Quote
Old 05-10-2004, 06:29 PM   #2 (permalink)
yup
Re: Pcv?
id take off the old one... blow in the end that the hose is connected to... air should flow through.... then blow in the other end... air should not flow through... thats all the pcv valve does so as long as those things occur there is no need to replace it
black 93 classic
Old 05-10-2004, 06:32 PM   #3 (permalink)
Team_LUMPIA
Re: Pcv?
do the shake test too. if u dont hear a rattle then it's clogged.
Ben
95 VZ-R/93 PRIMERA
BenSR20DE-T is offline   Reply With Quote
Old 05-11-2004, 11:50 AM   #4 (permalink)
f@%k the yankees!
Re: Pcv?
Thanx Fellas
Todd
