Old 05-10-2004, 10:26 PM   #1 (permalink)
b15 kid
Strut/GC clank issue
Ok my passenger side strut is clanking like a MOFO .......so i go into the trunk and look at the tops of each........the big middle bolt is tighteneted down good on the drivers side but on the passenger side the bolt is loose.......i tried tightening it but i got no where.......how can i get that bolt tightened up? the bolt was spinning and it wasnt tightening i even help the top part of the shaft that sticks out so that wouldnt spin .....HELP lol
StYLez Se-R is offline   Reply With Quote
Old 05-11-2004, 06:18 AM   #2 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 66 (100%)
Re: Strut/GC clank issue
Did you use a wrench to hold the shaft still while you tighten the strut bolt?
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Old 05-11-2004, 08:26 AM   #3 (permalink)
b15 kid
yea i held the top of the shaft with vise grips inside the trunk and tried to tighten the bolt with a wrench
Old 05-11-2004, 08:42 AM   #4 (permalink)
www.FAIRTAX.org
Vice Grips won't hold it as well. Use a wrench on the top of the strut shaft to hold it while you tighten the strut nut. You need an offset wrench for the nut.
Old 05-11-2004, 08:54 AM   #5 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
It sounds like you have a B14. You need to put some washers on top of the gold washer to act as a spacer. I had to do that for both of my rear shocks.
1991 Sentra SE-R
The community is here.
Old 05-11-2004, 10:26 AM   #6 (permalink)
SR20VE or a T28? I dunno!
What kind of wrench are you talking about? An adjustable one? I ended up breaking the top of my drivers side rear strut shaft when I was trying to tighten it down I'm just living with both sides clanking until I can get money up for a Tein setup...
Sam Bass / 1998 200SX SE-R
Atlanta, Georgia
98SERwTricks is offline   Reply With Quote
Old 05-11-2004, 10:38 AM   #7 (permalink)
www.FAIRTAX.org
Here is an offset wrench:
Old 05-11-2004, 10:41 AM   #8 (permalink)
I was asking about the best thing to use for the TOP of the strut
Old 05-11-2004, 10:45 AM   #9 (permalink)
www.FAIRTAX.org
Yes I know. Thats what you should use to tighten the nut on the top of the strut.
Old 05-11-2004, 07:32 PM   #10 (permalink)
b15 kid
ok so i look and my strut and the bolt and they are both stripped WFT........they must have been like this for awhile and been causing all that clanking......i hit a bump today and the nut like actually blew off........well is there anything i can do.......can i get the shaft of the strut like rethreaded or somthing or do i need to buy a new strut.......sh*t LOL can someone help me out....its my dailydriver and need it asap
Old 05-11-2004, 08:58 PM   #11 (permalink)
b15 kid
is it cool if i just rethread it .....then pull it back up the tower and put another bolt back on? or is it more complicated than that
Old 05-12-2004, 11:23 PM   #12 (permalink)
b15 kid
anyone help !
Old 05-14-2004, 07:52 PM   #13 (permalink)
b15 kid
comeon fellas?
Old 05-14-2004, 08:15 PM   #14 (permalink)
Sucks gas but kicks ass
impact that bitch with an impact gun
Missing my sr20 b14, but still showing some love. Possible new project when I return!
Old car: 1999 Sentra SE-L Turbo: USDM sr20de, t25 turbo, hot shot intercooler kit, BIG ass fmic, nismo fpr, autometer fp gauge/boost gauge, mbc set at stock boost for now! 7psi= more traction>11psi=less traction.
sr20det808 is offline   Reply With Quote
Old 05-14-2004, 08:18 PM   #15 (permalink)
b15 kid
but its striaght if i just pull it back into the tower......put the rubber piece on and then the metal top part then put the nut on and use the impact gun? or do i have to remove the mount at all?
