Old 05-11-2004, 03:47 PM   #1 (permalink)
Broke Ass
jer_760's Avatar
B14 MAF reground
I had this in the 200sx ser section but wasnt getting enough info so hear it is.
Ok, i searched and didnt get a positive yes or no answer. do b14 benefit from regrounding the MAF. if so which of the three wires is the ground? the middle one like the b13's?
95 200sx
sr20ve
Old 05-11-2004, 04:11 PM   #2 (permalink)
Re: B14 MAF reground
The middle one is the ground. I did it on my car, for just incase reasons.
Originally Posted by totaled200ser View Post
i would just run no manifold, you will gain the best flow. if you guys want to get 10 hp, why not buy a tornado?
Black98SeR is offline   Reply With Quote
Old 05-11-2004, 05:57 PM   #3 (permalink)
Broke Ass
jer_760's Avatar
where did you ground it to and do you have any pics?
Old 05-11-2004, 06:22 PM   #4 (permalink)
I just grounded it to the same place that the battery is grounded. Follow the ground off the battery, and you're golden. Sorry I don't have a cam, so i can't help you there.
Old 05-11-2004, 06:26 PM   #5 (permalink)
Broke Ass
jer_760's Avatar
good deal, thanx for the quick response
Old 05-11-2004, 06:52 PM   #6 (permalink)
Broke Ass
jer_760's Avatar
ok, i cant figure out where to splice the wire, do i just need to cut it in half then add the ground wire then solder them together? anyone have any pics showing exactly where they spliced and soldered? sorry for the stupidity.
Old 05-11-2004, 06:57 PM   #7 (permalink)
Basically I just cut the wire about 1 1/2 inches from the plus itself. Then I just connected a 8 gauge wire to it, and then I grounded it. easy as that.
Old 05-11-2004, 11:03 PM   #8 (permalink)
Broke Ass
jer_760's Avatar
alright, that what i needed to know. thanx for the info.
Old 05-12-2004, 10:12 PM   #9 (permalink)
yup
i managed to work the metal clip out of the plastic connector and then was able to crimp the new ground directly onto the connector. I wanted to do that incase the stock metal ground connector was making bad contact also... but it was a bitch getting the clip out with out breaking the plastic
black 93 classic
Old 05-13-2004, 12:57 PM   #10 (permalink)
SR20JET POWERED!!!
when i regrounded mine it didnt run right...i guess i did it wrong.
Xse-rX is offline   Reply With Quote
Old 05-13-2004, 05:29 PM   #11 (permalink)
Broke Ass
jer_760's Avatar
how did you do it Xse-rX?
Old 05-13-2004, 10:38 PM   #12 (permalink)
SR20JET POWERED!!!
I just cut the middle wire, and sliced a wire goining from the plug, and i grounded it to a open hole on the inner fender well. Im goining to try it again with a bigger wire and to my engine this time. I heard on b14s theres a ground in the ecu for the maf, but i assume it can have the same problem as the b13s did.
Old 05-14-2004, 11:37 AM   #13 (permalink)
Bitter Old Man
You guys NEED to read the MAF ground write-up either on SE-R.NET or the SE-R mailing list archives. The Nissan TSB shows a specific location for the extra ground and WHY.
Bruce in Houston
RIP swwwinger
Old 05-14-2004, 12:00 PM   #14 (permalink)
yup
http://www.se-r.net/engine/maf_ground.html i have checked this link and the all data tsb's. None of them explain why the ground needs to go to the back of the intake manifold versus directly to the battery ground or another chasis ground. Why is it that it needs to be grounded to this location???
Old 05-14-2004, 04:25 PM   #15 (permalink)
SR20JET POWERED!!!
ok, i just did it again, and soldered(sp?) the wire to the maf harness, and grounded it to the intake manifold. before my resistence was anywhere from .017 to .035! now it has none. I used a bigger wire than what theharness is so that might be the reason why theres no resistence.
Old 05-14-2004, 06:38 PM   #16 (permalink)
Broke Ass
jer_760's Avatar
i DID read the writeup on ser.net, i just needed to know if the b14 was different
Old 05-14-2004, 06:40 PM   #17 (permalink)
Broke Ass
jer_760's Avatar
what guage wire did you use? can you feel a difference?
Old 05-14-2004, 07:26 PM   #18 (permalink)
SR20JET POWERED!!!
i havent drove it yet, but i think i used 12 gauge, maybe ten i donno.
