Old 05-12-2004, 10:23 AM   #1 (permalink)
84.7 hp
ecoshardcore's Avatar
Approved vendor
im already sick of this car
ok so after searching for this and finding nothing of substance, ill ask a question. i have a 93 se-r, the problem is that when the engine is cold
it either bogs down or does nothing, when i come to a stop for the first time
it always sputters and dies. once the car warms up and i take it on the highway it feels like a geo metro (NO POWER). ive reached my wits end with
this car, if i cant figure it out its going to the junk pile
ecoshardcore is offline   Reply With Quote
Old 05-12-2004, 10:35 AM   #2 (permalink)
Re: im already sick of this car
If you're going to throw it on the junk pile I'll take it!
Seriously though, have you checked for a vacuum leak? The brakes need a good vacuum and if that is when it sputters and dies that could be a possibility.
Anyone else have a similar problem that can chime in?
'97 SE-R with BB T25 setup, G20 ECU, E-Manage, Starion FMIC, SPEC 6 puck stage 3 clutch, D2 coilovers, fully shaved doors including side molding, Royal Sapphire Pearl (Toyota Supra) paint, Halo headlights, Aerogear vented hood, 98 Sentra Grille, Vis Extreme front bumper, Andy's Autosport rear bumper, and Kenwood Excellon CD player (Formerly Raser-X's car)
http://www.uwm.edu/~elh3/Pictures/20...rbocharger.jpg
Tomcat5678 is offline   Reply With Quote
Old 05-12-2004, 11:28 AM   #3 (permalink)
Or...Deep Crystal Blue :/
Check your MAF voltages, and re-ground it....
1991 Aztec Red SE-R - T28 and some other fun stuff
1999 Deep Crystal Blue SE-L - Totaled 04/2007
SlateBlueSR20 is offline   Reply With Quote
Old 05-12-2004, 12:20 PM   #4 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 66 (100%)
The first thing you should to do is go to www.se-r.net and look in the maintenance and common problem areas. Follow the steps listed there and your problem will be solved.
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
paNX2K&SE-R is online now   Reply With Quote
Old 05-12-2004, 12:33 PM   #5 (permalink)
Off-Topic lurker..
Could be your AAC/IACV. A lot of SR20's have a problem with the AAC Valve sticking when the engine is cold, causing hesitation, stalling, and overall poor performance until the motor is warm.
Search for "cold idle fix" on SE-R.net. Without the ""
silversx is offline   Reply With Quote
Old 05-12-2004, 01:05 PM   #6 (permalink)
Devil's Advocate
Change your fuel filter also. It does wonders, especially if you have no power after its warm in the upper rpm's.
04 G35s Sport/6MT/NISMO Aero/Z-Tube/K&N Filter/Plenum Spacer/NISMO susp/Z Track wheels/G35c Brakes/Clear Corners/Stillen Sways
02 Vibrant Blue SpecV/NISMO CAI/ES MMI
92 Classic/U12/GTiR T28/ J.R.C. FMIC/Calum R/T ECU/Zt-2/300zx MAF/S15 inj/Apexi TT/Greddy Profec B/3" Turbo Back/Hyperco Gen II's/KYB AGX's/ES Mounts/Cluthnet Type 1 P/P-6 Puck Disc/Jun Flywheel/NX2K Brakes/Silver Kosei K-1's
Hybrid_DET is offline   Reply With Quote
Old 05-12-2004, 01:16 PM   #7 (permalink)
"Pimping aint Easy"
http://www.sr20forum.com/sr20de-technical-corner/38146-idle-problem-solution.html
do everything that thread talkes about.
your timing may be off aswell, or the knock sensor is retarding the time when you get down on it because you have vacume lines off or somthing just isnt right.
give the engine a little tlc and some brain power and it will love you for life.
Bust some knuckles, Leave some Blood and Skin!
http://home.comcast.net/~jjvphotography/susuki.jpg
1993 SE-R Gone to a good Home.
Still drive a volvo
and when its not raining a BIKE
Dropped89 is offline   Reply With Quote
Old 05-12-2004, 01:34 PM   #8 (permalink)
If you don't want it I'll take it off your hands. NO sense in throwing a classic into the junk pile.
