Re: How do you measure max lift on a set of cams?
I have a set of calipers btw...
A friend said to measure the smallest diameter on the lobe, and then the largest, largest - smallest, but I came up with something like 6mm that way.
I measured the camshaft, and then measured the camshaft + highest point on the lobes, subtracted the two and got ~11mm, which sounds about right for S3's...
am I totaly wrong in how I'm going about this?
