Re: how to remove tar paper with out chemicals
I've used dry ice on a 10 sec. RX-7 to strip the tar. Hard part was getting into very curved areas... would have to break up the chunk of ice and let it sit longer. Worked very well, most of the big flat areas came up in large pieces. From the back of the front seat to the rear tail lights we ended up shaving 6-8lbs.
What does your car weigh now without the tar, interior, or dash components?
1992 SE-R w/ bolt-ons (HS CAI, Stillen 4-1 Header, Catco Hi-flow Cat, custom mandrel 2.5" exhaust w/ Dynomax Ultra-Flo muffler, JWT S3 cams, Hyperco Gen2 springs, AGX's, S.T. anti-sway bars, UR pulleys, FSTB, JWT Pressure Plate, JWT Metallic/Organic Clutch Disc, Prothane motor mounts, NX2K brakes, braided brake lines, B&M Short Shifter, etc...)
