Old 05-13-2004, 03:37 AM   #1 (permalink)
da12lookout4
ecu question
i got the car from a used car dealer he says theres a ecu in the car its a 92 se-r is there another way to check other than revving it till it bounces of the limiter *** i heard the tachs are somtimes off it kicks back at 8k when in first
stolen is offline   Reply With Quote
Old 05-13-2004, 03:44 AM   #2 (permalink)
Or...Deep Crystal Blue :/
Re: ecu question
Im confused, are you saying there is a chance the car came without an ECU?
Anyways....Of course there is an ECU in the car, otherwise it wouldnt run at all....
If you are asking if there is a rev limiter, there is...the ECU is programmed to cut off. Redline is 7500, I wouldnt recommend going any higher to test the rev limiter.
1991 Aztec Red SE-R - T28 and some other fun stuff
1999 Deep Crystal Blue SE-L - Totaled 04/2007
SlateBlueSR20 is offline   Reply With Quote
Old 05-13-2004, 03:46 AM   #3 (permalink)
da12lookout4
Re: ecu question
no im not saying theres a chance it came without an ecu i meant to say chip or a jwt ecu
Old 05-13-2004, 03:50 AM   #4 (permalink)
Re: ecu question
Well, the actual Rev limiter is 7700 on a stock ecu. If you take the ECU out, it will say whether it has been re-programmed by JWT (sticker with the program added).
Old 05-13-2004, 03:59 AM   #5 (permalink)
da12lookout4
Re: ecu question
ok i hope i find a jwt what else can i look for when i open it up
Old 05-13-2004, 04:08 AM   #6 (permalink)
Re: ecu question
Well, aside from JWT, I dont know of anyone that does ECU "chipping" or programming, but there are a few guys who have replaced the crystals to get a higher rev limiter..thats a possibility as well, but unlikely.
Josh
Old 05-13-2004, 08:43 AM   #7 (permalink)
Re: ecu question
Just to let you know, you don't have to open the ECU actually. JWT usually puts stickers on the outside.
'97 SE-R with BB T25 setup, G20 ECU, E-Manage, Starion FMIC, SPEC 6 puck stage 3 clutch, D2 coilovers, fully shaved doors including side molding, Royal Sapphire Pearl (Toyota Supra) paint, Halo headlights, Aerogear vented hood, 98 Sentra Grille, Vis Extreme front bumper, Andy's Autosport rear bumper, and Kenwood Excellon CD player (Formerly Raser-X's car)
http://www.uwm.edu/~elh3/Pictures/20...rbocharger.jpg
Tomcat5678 is offline   Reply With Quote
