Old 05-13-2004, 05:53 PM   #1 (permalink)
_scott
CivicsSuck's Avatar
Is it Possible?
When putting the clutch together, is it possible to put the clutch disc on backwards? Or will it hit the flywheel bolts and it would be noticable that it's on backwards?
Very Curious, Thanks.
13.29 - 108 mph
226whp 225trq
My Avenir Project:
http://www.sr20forum.com/members-rides/157517-avenir-section-402-a.html
06 Frontier, Nismo package
http://memimage.cardomain.net/member...51_26_full.jpg
06 Honda 450R, few goodies
http://memimage.cardomain.net/member...51_27_full.jpg
CivicsSuck is offline   Reply With Quote
Old 05-13-2004, 06:10 PM   #2 (permalink)
rollin 4 deep with JoeD
Re: Is it Possible?
ITs possible.
Frank Orozco
cnynracer1 is offline   Reply With Quote
Old 05-13-2004, 06:12 PM   #3 (permalink)
_scott
CivicsSuck's Avatar
Re: Is it Possible?
Don't know the correct way off the top of your head do you? Or even know somewhere I could see a pic??
Old 05-13-2004, 06:17 PM   #4 (permalink)
_scott
CivicsSuck's Avatar
Re: Is it Possible?
Actually do you think that would cause symptoms of hard shifting, but could drive around, and then not being able to put into gear unless the car is turned off?
Old 05-13-2004, 07:13 PM   #5 (permalink)
Re: Is it Possible?
there was a forum member who put his on backwards a while back and posted some pics. he ran it like that for a while and didnt even know it.
n2nismo is offline   Reply With Quote
Old 05-13-2004, 07:17 PM   #6 (permalink)
Re: Is it Possible?
found the thread but the pics of the clutch arent there anymore.
http://www.sr20forum.com/showthread....utch+backwards
Old 05-13-2004, 07:40 PM   #7 (permalink)
_scott
CivicsSuck's Avatar
Re: Is it Possible?
I think, since I've tried everything I can, that the tranny is actually the problem. If so, sorry but, Mother fu*ker! I purchased the tranny from a place called Midway Auto Inc. in New Jersey, must be a junk yard or something, for $575 shipped. Struggle to put it in after waiting for the Fidanza flywheel to come in and take it for a spin. Everything works, just hard to shift (especially first gear), so I go home to adjust it. Get home adjust it, go ahead start it up, go to put it in gear and nothing works. Nothing goes in and reverse grinds.
So ending conclusion the tranny itself has to be fu*ked.
