Re: Stalling on ignition, bucking and sputtering
does the car actually die? right after starting?
if you give it gas right after starting does it keep the car from stalling?
sounds like you might have the same idle problem as everyone
things to check:
O2 sensor - how old is it?
fuel filter - if it is dirty replace it with a 300zxtt filter
idle speed - should be 850rpm
IAC/AAC valve - these get very dirty and will go bad with time
EGR - is it clogged
MAF - have you regrounded it?
1993 Nissan Sentra SE-R
Soko motor, OBX header, HKS exhaust, clutchnet fibercarbon
