Old 06-17-2004, 10:52 PM   #1 (permalink)
SE-Rious
Car running at 260F too hot????
And I know ive asked this question before and have thousands of same forums but I havent had it answered yet, Do I need to replace the 2 wire sensor???? Or is that ONLY for the fans and doesnt effect the gauge reading or car heating, and does anyone know the proper way to bleed cooling system???????????????????????????????????????????? ???????/
93' SR20DE BLUEBIRD SSS ENGINE-SE-R ECU-G20 MAF-STILLEN VELOCITY STACK INTAKE W/ K&N-OBX RACING HEADERS-HIGH FLOW CAT-REAR SECT. EXHAUST W/ MAGNAFLOW XL-VLSD-MEGAN SHORTSHIFTER-MEGAN STRUT BAR-ELIMINATED A/C COMPLETELY-AND A FEW TWEAKS- SE-R WHEELS,MICHELLIN TIRES-AR ALUMINUM SPOILER-MOMO-
"SR20 FOUR DOOR WHORE"
krstich is offline   Reply With Quote
Old 06-17-2004, 11:07 PM   #2 (permalink)
My Ass, your face
vladha's Avatar
Re: Car running at 260F too hot????
http://www.se-r.net/zotz/se-r_coolant_change.htm
The 2 wire sensor is to the ecu, the 1 wire is to the gauge... at least for the highport sr20de.
I used Ricks procedures on a lot of things, the coolant writeup is very clear and direct.
Hope this helps... visit se-r.net and you'll find even more information.
Peace,
Mark
vladha is offline   Reply With Quote
Old 06-17-2004, 11:27 PM   #3 (permalink)
SE-Rious
Thank You Soooooooooo Much Vladha!!!!!!!!
Old 06-17-2004, 11:27 PM   #4 (permalink)
SE-Rious
does anyone know if 260/265 is too hot??? or hot enough to blow a gasket???
Old 06-17-2004, 11:46 PM   #5 (permalink)
Undecided
Uh....... I have a BB DET and I run the sh*t out of my car. I also removed one of the fans. On an 80 degree day in stop and go traffic I only see 210 at the most. 265 is wayyy too hot. Buy an FSM man, its the bible to your nissan.
97SE-R
1/8 8.6@ 85
R.I.P. John
97SE-R C2 is offline   Reply With Quote
Old 06-18-2004, 12:48 AM   #6 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
Mine sits at 180 deg, unless I'm stopped for awhile. It sounds like kept the JDM sensor, and its giving the wrong info.
1991 Sentra SE-R
The community is here.
Old 06-18-2004, 02:12 AM   #7 (permalink)
SE-Rious
I do have the 2 wire JDM sensor but replaced the "sender unit" to the gauge with a brand new one!!!! DOES ANYONE KNOW IF I HAVE TO REPLACE THE 2 WIRE ONE TO GET ACCURATE GAUGE READINGS?????????????????????????????????????????? ????????????????????
and dont the fans kick in at 220?
Old 06-18-2004, 02:24 AM   #8 (permalink)
banned
do you have a usdm sensor or jdm and what ecu do you have
Whitelightening is offline   Reply With Quote
Old 06-18-2004, 03:46 AM   #9 (permalink)
SE-Rious
I have the JDM Sensor (two wire to ecu),and have the USDM temp sender brand new (one wire to gauge),and I have the jdm u13 ECU.
Anyoe used Redline water wetter? does it really help??
