Old 06-19-2004, 12:00 PM   #1 (permalink)
can't get into timing mode
I've read all the posts here, used charlie2020's write up on how to get into timing mode. Tried the one on se-r.net and the one from the FSM. I've probably tried to get into timing mode over 20 times. The reason I need to get the car into timing mode is my idle is very inconsistant and I think my timing is off. I've followed all the procedures (they're all similar) exactly, but once uplugging the TPS (or TPS + IACV) the car will idle from 500-700 or at above 1200 depending on how i turn the idle adjust screw, I can never get it to go to 750ish, it's always +- 200rpms. So it ends up I adjust the timing and idle anyway, but both are off. I can't get my timing to remain steady, and like I said the idle is different every other day (sometimes at 800, sometimes at 1100, sometimes the car won't idle). Any ideas? For the most part the car runs great at speed. Would going to a nissan dealer and hooking up to a consult help?
webninja is offline   Reply With Quote
Old 06-19-2004, 02:32 PM   #2 (permalink)
Re: can't get into timing mode
warm up your car then remove the tps. ground the 2 wires on the tps (black and pink) with a paper clip or something similar. then adjust your base idle first then your timing.
VZ-R
TEIN HA, Cusco 4pt. underbrace, Nismo mounts, S4 cams, Pulleys, Headers, Exhaust- RSR, Sard Radiator & 1.3 bar Cap, AEM CAI, B&M short shift, SMC BABK with Maxima rears, 17" TE 37 white, 15" TE 37 bronze, Gull sport Racing seat, Willans 4pt. Harness, Axel bending by westend, JDM headlights and corner lights, Stillen rear sway bar, Greddy RAS, Thermoblock
lucino vzr is offline   Reply With Quote
Old 06-19-2004, 03:16 PM   #3 (permalink)
a real egg-head
check your ecu for codes, you may be suprised
-Mike
1992 NX2000, 1998 Honda Civic
60' 1.997 --- 1/8mi 8.387 @ 84.15--- 1/4mi 13.095 @ 103.29 mph
Click here to see my nx2000!
nx2000racer is offline   Reply With Quote
Old 06-19-2004, 04:24 PM   #4 (permalink)
never heard of grounding the tps, but i'll try that. I've checked the ECU for codes and I get one for EGR (it's removed) and rear 02 (also removed).
Old 06-19-2004, 06:54 PM   #5 (permalink)
Primera Nut
Or get a consult interface and laptop, then it's just the click of a mouse button....
My Cardomain page and My website check them out
markbuts3 is offline   Reply With Quote
Old 06-19-2004, 10:04 PM   #6 (permalink)
Clear those codes and try again. They will probably come back everytime you turn the car off and back on. Keep clearing them until you finish. Set your idle, then your timing.
98 200SX SER
spudnex is offline   Reply With Quote
Old 06-19-2004, 10:40 PM   #7 (permalink)
you'll be surprise what a little piece of wire can do.
Old 06-20-2004, 01:18 AM   #8 (permalink)
sr20 addict
shouldn't the base idle be at like 700rpm cause mine idle's at like 1000 rpm and the idle screw doesn't work at all....can i still time the car????
White 93 SE-R
Mods:
JWT POP
JWT S3's
JWT PP & Disc
OBX Header
VRS 2.5 Cat-back
Eibach Springs on KYB AGX's
B&M SS
Hyperflex Kit
http://memimage.cardomain.net/member_img_a/574936_36_full.jpg[/img]
///M5 is offline   Reply With Quote
Old 06-20-2004, 02:15 AM   #9 (permalink)
Enjoy the GTR Matt!
Trader Rating: 23 (100%)
Hey, we're trying.. I hopped in line a few months ago, and I'd guess maybe in a few months I'd have that luxury!
Old 06-20-2004, 03:42 AM   #10 (permalink)
Primera Nut
Hehe.....got mine a few days after ordering....
Old 06-20-2004, 06:08 AM   #11 (permalink)
It depends on what mods you have. If you have s3/s4 program, the idle should be 850 to 950 rpm and the timing should be at 15*.
What do you mean by the idle screw doesn't work? If your base idle is not set, then, you're going to have a hard time adjusting your timing and idle screw. Everytime you try to adjust your (timing) distributor, your rpm goes up or down. Try doing what I said, then adjust your idle and then timing.
Old 06-21-2004, 10:44 PM   #12 (permalink)
you guys were right about the ecu codes, I cleared them and the idle was better. Had an appointment at the dealer this morning, so I didn't mess with the idle or timing too much. When my car was hooked up to the consult, we got it into timing mode and set it at 15. I did get lots of errors for faulty IACV valve. Only problem with that is my IACV and Air Regulator are less than a month old items from Mossy Nissan. What are the chances that the new IACV is bad? Could there be something else that throws the IACV off? I'm going to double check the install, might remove it and reinstall it, just to be sure. The car does run a bit better now that the timing and idle are right. Just that idle couldn't be set perfect becuase the ecu keeps throwing the faulty IACV code.
Old 06-22-2004, 12:20 PM   #13 (permalink)
Tired Greasemonkey
i'd guess that the idle couldn't be set perfect because the IACV is bad, not the ecu preventing it.
