Old 06-19-2004, 06:39 PM   #1 (permalink)
the fo do
tach and water temp plugs
I just installed a new clutch. i hooked all of the wiring harness plugs back up and went to turn the car on and the tachometer and water temp gauge do not work. Are those 2 wires for those on the same plug? Everything is hoooked up so if anyone has some input. thx
se-riousclassic is offline   Reply With Quote
Old 06-19-2004, 07:19 PM   #2 (permalink)
the fo do
Re: tach and water temp plugs
anyone!?
Old 06-20-2004, 02:49 AM   #3 (permalink)
SE-Rious
the temp gauge wire is by the oil filter, the tach im not sure but i doubt its on the tranny stock?
93' SR20DE BLUEBIRD SSS ENGINE-SE-R ECU-G20 MAF-STILLEN VELOCITY STACK INTAKE W/ K&N-OBX RACING HEADERS-HIGH FLOW CAT-REAR SECT. EXHAUST W/ MAGNAFLOW XL-VLSD-MEGAN SHORTSHIFTER-MEGAN STRUT BAR-ELIMINATED A/C COMPLETELY-AND A FEW TWEAKS- SE-R WHEELS,MICHELLIN TIRES-AR ALUMINUM SPOILER-MOMO-
"SR20 FOUR DOOR WHORE"
krstich is offline   Reply With Quote
Old 06-20-2004, 09:59 PM   #4 (permalink)
the fo do
I didn't touch those when i did my clutch swap and i unplugged them and replugged it. They were all connected well. Is there anywhere in the harness that the wire for temp gauge is on teh right side of the transmission? It worked fine before clutch install, and all of the harness is hooked up right. any help?? =\
Old 11-20-2005, 11:30 PM   #5 (permalink)
Pimpin Aint EZ'
I have the same problem with my Tach...what did you do to fix it?
-B
91 SE-R Gti-R swap [PARTED OUT]...99' Infiniti G20T
Spec-V-n-NyC is offline   Reply With Quote
Old 02-01-2006, 01:44 PM   #6 (permalink)
Black Out
hate to bring up a really old thread but I have the same problem. Did anyone find a solution?
nissasin is offline   Reply With Quote
