Old 06-20-2004, 02:41 PM   #1 (permalink)
wants to go play
Blair's Avatar
checking cam timing
I think my NX jumped a tooth at start up. Is there any way to check the timing without tearing the motor apart?
93 SE-R (daily driver)
Old 06-20-2004, 05:09 PM   #2 (permalink)
a real egg-head
Re: checking cam timing
with # 1 cyl at TDP the intake cam is supposed to be at 10 o'clock and the exhaust should be 12. This has to be the worst setup i've ever seen. You can have the exhaust pointing straight up, and it can be 1 tooth or the one next to it, which is right?
setting up the cams in relation to eachother is solid, 20 rollers between the dots on the cam gears. But in relation to the crank, there has to be a better way.
we need some solid say of checking it, and pics would be great.
im gona pull my vc and take pics of mine, im not even sure if its right.
-Mike
1992 NX2000, 1998 Honda Civic
60' 1.997 --- 1/8mi 8.387 @ 84.15--- 1/4mi 13.095 @ 103.29 mph
Click here to see my nx2000!
nx2000racer is offline   Reply With Quote
Old 06-21-2004, 05:14 PM   #3 (permalink)
a real egg-head
we really need some answers here...
i should have pics later today of mine
Old 06-21-2004, 07:23 PM   #4 (permalink)
a real egg-head
ok here we go, i pulled everything apart because i need answers.
Look closely, are the cams advanced 1 tooth? they look like they are a hair to the right. Also with a timing light the flash is way past the marks with the tps unplugged at like 1300 rpm, when i plug in the tps the flashes come back to the marks on the pulley.
Old 06-21-2004, 07:45 PM   #5 (permalink)
vincit omnia veritas
You have to keep turning the engine untill the marks on the timing chain show up *and* show up @TDC on #1.
I can't see the marks in your pictures.
Once you get it to turn and you see the marks and it lines up on one or both cams when it is on TDC on #1 you will be able to tell if you skipped a tooth or not.
The only way you can tell if you skipped a tooth is if you have the chain in the right position *as well* as the cams in the right position.
You need a FSM if you don't have one already. Period.
hope that makes sense.
David Lau email:rockitstock@comcast.net
PNWser is offline   Reply With Quote
Old 06-21-2004, 09:51 PM   #6 (permalink)
are you using a timing light on the gears? if so, why?
ncSE_R is offline   Reply With Quote
Old 06-21-2004, 10:11 PM   #7 (permalink)
a real egg-head
im definately not that stupid
Old 06-21-2004, 10:14 PM   #8 (permalink)
i didnt mean for you to think that.....sorry
Old 06-21-2004, 10:16 PM   #9 (permalink)
a real egg-head
its all good, i would just love to figure out whats wrong here.
Old 06-21-2004, 10:18 PM   #10 (permalink)
first off, is the number 1 cylinder on the compression stroke?, or are you 180 out?
Old 06-21-2004, 11:56 PM   #11 (permalink)
Give me fuel,give me fire
you can tell by the pictures that it is on the correct stroke. If it skipped on the crank sprocket than things get not so easy b/c the marks can line up on the i/h sprocket but still be incorrect.
There was a good post by 99SE-L that said how to correct your timing. I feel your pain though this happened to me.
92 Sentra SER JDM mad tyte yo!
95 200sx SER purple somewhere on the side of the road in Arizona
Nismo_SR20 is offline   Reply With Quote
Old 06-22-2004, 12:40 AM   #12 (permalink)
how? arent the crank gear and the sprockets close to a 2:1 ratio? I know they shouldnt be 1:1.??
Old 06-22-2004, 10:22 AM   #13 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
Everything looks okay to me. I always put the exhaust cam at 12:00, then count back 20 pins, and line the intake cam up from there. Try adjusting your idle down to 800 or 900 rom and recheck the timing. You may have to unplug the AAC valve for the idle to drop.
1991 Sentra SE-R
The community is here.
Old 06-22-2004, 11:48 AM   #14 (permalink)
owned by SE-Rs!
it looks fine by those pics, 20 pins for sure
Nick McCollom
99 Infiniti G20
93 Nissan NX2000 14.027 @97.98 (N/A) I wish I had time and money again, this little car has sat for 2 years now. I do miss driving it bad. It will be back soon though faster than ever.
http://www.cincyclubclub.com/lilly/littlefamily.jpg
sakerocket1 is offline   Reply With Quote
Old 06-22-2004, 08:46 PM   #15 (permalink)
have you checked your ignition timing yet? that would tell you if you are off on the exhaust side atleast.
Old 06-22-2004, 09:25 PM   #16 (permalink)
owned by SE-Rs!
Also I dont think they just jump a tooth. I dont think they can. Unless the tensioner is done but still I think htat would be ok.
Old 06-22-2004, 09:27 PM   #17 (permalink)
a real egg-head
i have officially proved it is possible to get the crank to jump a tooth, or 2....
check out the post...
http://www.sr20forum.com/sr20de-technical-corner/81421-cam-dowel-marks-mine-right.html
