Long story short-->Checking for bent valves
I over revved my sr20de and broke 1 rocker arm on #1 cylinder intake side. The spark plug in #1 cylinder was oil or gas soaked, and compression was at 40 psi. I replaced the broken rocker arm and fired it up, but it still ran the same. At this point I thought for sure it was a bent valve. I now have the cylinder head off, and looking at the piston head, and the valves they look fine, doesnt appear to have been any contact. Is there anything else I should look for? I tried to remove the valve springs, but the tool I have doesnt fit right.
Thanks
