Old 06-20-2004, 09:48 PM   #1 (permalink)
B15 Bubble
Oxygen Sensor/related problem
I have a reoccuring code on my 2000 Sentra SE, which is P0135. The FSM point to the heater sensor on the front O2 sensor. I know the sensor is not the problem, because I swapped my sensor out for another one and the code returns.
I cut the heater sensor wire at the O2 sensor and ran a BRAND NEW wire from the sensor to the ECU. At the ECU I cut wire number 4 (Which was Red and black), and soldered the new wire into that. Still no change, the P0135 error comes back right away.
With fustration mounting I decided to disconnect the O2 sensor alltogether and see what happens. If I disconnect the O2 sensor alltogether I still get the same P0135 error right away. The wierd thing is that at no point do I recieve the a P0130 (Heated O2 sensor circuit) error, which I think I should recieve seeing as the O2 sensor is NOT CONNECTED AT ALL! I am thinking maybe the ECU is not seeing the front O2 sensor at all?
I am running out of time to get my car inspected! Any thoughts?
cburwell is offline   Reply With Quote
Old 06-22-2004, 09:38 PM   #2 (permalink)
B15 Bubble
Re: Oxygen Sensor/related problem
Problem solved! I completely forgot about the second fuse box INSIDE the car! A simple 15A fixed the problem!
Old 06-28-2005, 03:13 PM   #3 (permalink)
FWD PWNAGE IS HERE!
Hey were you throwing the heater sensor circuit malfunction code?
'93 240SX - Stock for now
'95 G20 - The DD - 210K and counting
'96 G20 - Beating up the streets of SL,UT.. watch out - 334WHP/313TQ
www.UtahNissans.com
www.RallySportDirect.com
SR20 Inside is offline   Reply With Quote
