Old 06-21-2004, 03:16 AM   #1 (permalink)
315LB CLUB [][]-----[][]
messed up fuel rail?
My car is been idleing alittle funny since i put the the engine in, but it really hasnt been all that bad. And I was looking at the fuel rail today, and i came across one of the injectors isnt sitting all the way down in the manifold. It looks as though when someone was putting on/taking off a delivery truck, they hooked on the the fuel rail to do so. Ill get some pictures of what it looks like tomorrow, but I was wondering if its possible to somehow knock the injector back down into the manifold all the way. It also looks like gas is leaking its way around the black seal that it fits into, so i dont know if that could be affecting gas milage, performance, idle, etc. Thanks.
'99 Sentra SE-L
'91 Sentra SE-R sold
FloridaSR20s
Thomas
sr20sentra91 is offline   Reply With Quote
Old 06-21-2004, 12:01 PM   #2 (permalink)
penetration specialist
Re: messed up fuel rail?
Same thing happened with mine. As far as i can tell i'm getting a miss from it. Reason being, if I force the fuel rail slightly it gets worse. I'm trying to get a replacement to find out for sure but i will keep you posted.
classico 92
flsoundfx is offline   Reply With Quote
Old 06-21-2004, 12:52 PM   #3 (permalink)
i had the same problem with the rail when i received mine last year...it's how they hook it when they lift the motor. jgy sent me a new one right with it though so it wasnt to much of a problem for me.
Mark
95 se-r, avenir, HS fmic piping, spearco ic, calum realtime ecu, 3" jgy dp, 3" inlet magnaflow with 2 2.5" outlets out front each rear tire, walbro, nismo fpr, summint fpg, 2 10" pusher fans, koyo radiator, ats comp lites wrapped in azenis, on tein basics w/ pillowballs up front. Now featuring a gt2871r on JGY mani, and S3 cams!
ser_smokes_alot is offline   Reply With Quote
Old 06-21-2004, 04:01 PM   #4 (permalink)
my fuel rail was the same way on my soko motor so I jsut use the one from my stock motor
1993 Nissan Sentra SE-R
Soko motor, OBX header, HKS exhaust, clutchnet fibercarbon
focalBlur is offline   Reply With Quote
Old 06-21-2004, 05:06 PM   #5 (permalink)
No soup for you
Trader Rating: 30 (100%)
if the injector does not fit in teh rubber pice correctly it will cause a vaccum leak. Get a replacement rail ASAP. Further more, depending on the bend it could impede fuel flow across the rail.
John
B12 turbo madness
424 whp / 328 ft. lbs
2440 lbs. w/ a full tank
B14 VE Hotness
244 whp / 228 ft. lbs
Old 06-21-2004, 06:08 PM   #6 (permalink)
so from what i hear Im not the only one that got a engine shipped like this...i dont have my old engine anymore, so i guess ill have to pick up a fuel rail from someone. thanks for all your help guys!
Old 06-21-2004, 06:30 PM   #7 (permalink)
vincit omnia veritas
Lots of engine importers use the fuel rail as a lift point. Makes the fuel rail a POS!! lazy bitches!
swap it to your USDM rail- or PM me if you need a good rail
David Lau email:rockitstock@comcast.net
PNWser is offline   Reply With Quote
Old 06-21-2004, 06:55 PM   #8 (permalink)
bla bla bla
those things are EXPENSIVE from the dealer too just under $200 list price (fyi)
2003 VW gti 1.8t
72 Datsun 510-sold
Old 06-21-2004, 11:59 PM   #9 (permalink)
that expensive just for that (in my opinion) but thanks for the info
Old 06-22-2004, 09:08 AM   #10 (permalink)
I was installing my NOS DP kit and pulled off the rail and noticed that it was kinked bad So I replaced it with the one off my old motor.
http://img57.photobucket.com/albums/...R/Dscf0011.bmp
13.3 @ 107.91 MPH
2/15/2004
Check out:
www.powertechimports.com
TRUSE-R is offline   Reply With Quote
