Old 06-21-2004, 05:21 PM   #1 (permalink)
the fo do
transmission fluid leak
I noticed after i installed my clutch there was a little bit of tranny fluid dripping where the shift rod connects to the tranny. Could it be the wrong type of fluid im using to cause it to leak?
se-riousclassic is offline   Reply With Quote
Old 06-22-2004, 07:39 PM   #2 (permalink)
DBA/IT
Trader Rating: 19 (100%)
Re: transmission fluid leak
I doubt the type of tranny fluid matters. Check your seals, they may be leaking. My driver side axle seal is leaking a little a day, and I definitely need to get it fixed before my tranny gets worse -_-
http://www.rollyourcar.com
Old 06-25-2004, 11:40 PM   #3 (permalink)
/// God Speed! ///
That is kinda a odd place for it to leak. Are you sure the reverse light switch isn't the cause instead, or the PS axle seal?
Darren
E-Mail: Its311Pete@alltel.net
9.277 in 1/8 2.023 60ft
91 Classic w/ a few bolt ons.
http://img.photobucket.com/albums/v3...wse-rsmall.jpg
Its311Pete is offline   Reply With Quote
Old 06-26-2004, 12:07 AM   #4 (permalink)
_scott
CivicsSuck's Avatar
Don't be suprised if that is where it's coming from, where the shift rod goes into the tranny?? I had this happen to me, I had to bring the tranny down to a tranny shop and had them rip it apart and replace the seal. Damn expensive for a seal, but it stopped the leak.
What really sucks is that the tranny that I did this to was my 3rd one in there. I ended up wheel hopping it to death on my first run of the night at the drags. And I ended up killing a good $800 tranny.
So again it is possible that it is coming from there. Sorry, I just had to tell my sad story.
13.29 - 108 mph
226whp 225trq
My Avenir Project:
http://www.sr20forum.com/members-rides/157517-avenir-section-402-a.html
06 Frontier, Nismo package
http://memimage.cardomain.net/member...51_26_full.jpg
06 Honda 450R, few goodies
http://memimage.cardomain.net/member...51_27_full.jpg
CivicsSuck is offline   Reply With Quote
Old 06-26-2004, 01:21 AM   #5 (permalink)
sr20 addict
Yeah Mine Leaks Too But Not Enough Too Worry About I Just Make Sure It Has Fluid In There Every Once And A Whle
White 93 SE-R
Mods:
JWT POP
JWT S3's
JWT PP & Disc
OBX Header
VRS 2.5 Cat-back
Eibach Springs on KYB AGX's
B&M SS
Hyperflex Kit
http://memimage.cardomain.net/member_img_a/574936_36_full.jpg[/img]
///M5 is offline   Reply With Quote
Old 06-26-2004, 02:21 AM   #6 (permalink)
SR20JET POWERED!!!
mine used to leak from therelike crazy, then i broke it.
Xse-rX is offline   Reply With Quote
Old 06-26-2004, 02:50 AM   #7 (permalink)
the fo do
yeah i just did a clutch install and the shift rod seemed like it came out a lil when it was on teh stand to put up on motor and i pushed it back in. It is only a slight leak, but it didn't leak before. =(...
Old 06-26-2004, 02:51 AM   #8 (permalink)
the fo do
also that rubber boot that goes over the shaft will not stay on. The shaft is kinda exposed. How can i keep that rubber seal on there?
