cam dowel marks, are mine right? - Page 2 - SR20 Forum
Old 06-23-2004, 10:43 AM   #21 (permalink)
a real egg-head
Re: cam dowel marks, are mine right?
ok heres my idea now... since i have access to the chain on the CRANK sprocket, if i mark the 1st roller, and mark the last mark before the exhaust cam, wont that guarantee the timing? i believe it is 48 links between exhaust dot and crank dot?
-Mike
1992 NX2000, 1998 Honda Civic
60' 1.997 --- 1/8mi 8.387 @ 84.15--- 1/4mi 13.095 @ 103.29 mph
Click here to see my nx2000!
nx2000racer is offline   Reply With Quote
Old 06-23-2004, 07:46 PM   #22 (permalink)
just workin'
he may have the cam timing correct from looking at it now, what i said should only be done if you cannot hit 15* ignition timing with the dizzy near the center, only move if you have a problem getting you ignition timing near 15* with the dizzy in the middle. if you have no problem with that and your idle is somewhat smooth, i don't think you have a cam timing issue
DnS Performance
Imported Auto Center, INC
96 g20 auto, stock
totaled200ser is offline   Reply With Quote
Old 06-24-2004, 01:05 PM   #23 (permalink)
TT Tuning
Feedback Score: 7 reviews
you should beable to get the crank dot to line up and fix it at the cams...thats what i did. not to bad,lot easer then pulling the timing cover and oil pans.
91 se-r the key is still stock. SOLD
http://img.photobucket.com/albums/v2...e-rpics025.jpg
http://img.photobucket.com/albums/v2...frontangle.jpg
01 dodge cummins 460/930 sold
03 dodge cummins ???
08 maxima stock
afstegg is offline   Reply With Quote
Old 06-24-2004, 01:10 PM   #24 (permalink)
Give me fuel,give me fire
That is a good idea, it will tell you if you need to advance/retard the exhaust side. After you fix the exhaust side count 20 pins over and put on the intake sprocket.
92 Sentra SER JDM mad tyte yo!
95 200sx SER purple somewhere on the side of the road in Arizona
Nismo_SR20 is offline   Reply With Quote
Old 06-27-2004, 09:45 PM   #25 (permalink)
Pimp Sh*t
update?
Murfreesboro Sleeper Street Sweeper
91 SE-R--lots of mods SOLD
The Wolf
01 Jetta Wolfsburg 1.8t--APR 93/100 oct chip, TT 2.5" Downpipe, Forge 007, n75j, custom intake, votex springs
b13speed is offline   Reply With Quote
Old 06-27-2004, 09:54 PM   #26 (permalink)
a real egg-head
im putting a motor in it
i think the problems go beyond cam timing.. i pull the wires off of 2 and 3 and you barely notice a difference, the car hesitates bad enough to hit your face on the steering wheel... etc...
im done screwin with useless sh*t, ill start from scratch.
Old 11-18-2011, 02:04 PM   #27 (permalink)
Sorry to bring up an old thread, but it seems like I'm not the only one that had difficulty verifying the timing to the cam shafts. Does anyone here want me to do a write up on the subject?
lophilip is offline   Reply With Quote
