cam dowel marks, are mine right? - SR20 Forum
Old 06-21-2004, 06:25 PM   #1 (permalink)
a real egg-head
Im posting this here also because i need answers.
Heres pics of my marks, and dowel pins, do they look right?
-Mike
1992 NX2000, 1998 Honda Civic
60' 1.997 --- 1/8mi 8.387 @ 84.15--- 1/4mi 13.095 @ 103.29 mph
Click here to see my nx2000!
nx2000racer is offline   Reply With Quote
Old 06-21-2004, 06:37 PM   #2 (permalink)
95NismoB14grl
Re: cam dowel marks, are mine right?
If your wondering if your cam timing is off then, fifth pic down shows the gold chain link on the intake side coming up..that link is supposed to be ont he cranks when the cams are in that position....you need to rotate the motor over witht he chain tensioner in till the timing marks line up like that with the different color links above the dot on the cam gears..i dont remember how many turns but its a few....then the cams should be in that position your in now but all the chain links correct.
Hope i didnt read into this too much...maybe i dont understand the post???
05 GSXR600
05 Altima SE-R
98 Maxima SE
92 Turbo Classic-SOLD
Top Tech Motorsports
TT Tuning
Nismo91ser is offline   Reply With Quote
Old 06-21-2004, 07:06 PM   #3 (permalink)
natural81
Feedback Score: 11 reviews
looks like your intake cam might be one tooth off..you need to go on tooth to your right if your standing right in fron of it. how does it run in the position they are right now? also make sure the timing mark lines up perfect with the first line on the left on the crankpulley...
Jose is offline   Reply With Quote
Old 06-21-2004, 07:18 PM   #4 (permalink)
TT Tuning
Feedback Score: 7 reviews
the exshaust one is off ...crapy pics. theirs one silverlink that is on the crank gear and two darker ones that line up with the cAm gears. the pics you show have the exshaust a 1/2 link off. the dot on the cam should line up with the colored link
91 se-r the key is still stock. SOLD
http://img.photobucket.com/albums/v2...e-rpics025.jpg
http://img.photobucket.com/albums/v2...frontangle.jpg
01 dodge cummins 460/930 sold
03 dodge cummins ???
08 maxima stock
afstegg is offline   Reply With Quote
Old 06-21-2004, 08:07 PM   #5 (permalink)
a real egg-head
heres a brighter pic
how could only 1 cam be off if there are 20 rollers between the 2?
the car is perfectly fine in terms of driveability. But its half a second slower in the 1/4 mile.
I have a code 34 for knock sensor, if the cam is advanced, which makes the timing advanced, causing knock, would the ecu throw a knock sensor code because the engine is knocking? or just because the sensor is bad?>
Old 06-21-2004, 08:34 PM   #6 (permalink)
sleeper
looks fine to me? has 20 rollers in between. sure way to know is to turn the motor over until you get to the yellow links I believe.....
Khiem
'05 Evo
'05 CBR 600RR
Old 06-21-2004, 08:42 PM   #7 (permalink)
lack of sr20 owner
bump!!! I would like some cold hard facts on this issue. I might be in the same predicament.
2001 WS6
NateSR20 is offline   Reply With Quote
Old 06-21-2004, 08:49 PM   #8 (permalink)
a real egg-head
i beleive this is what you are looking for, now that my arm is about to fall off
they are hard to see, but the links are on the right side of each dot on the gear. To see what i mean, the exhaust cam gear shows it well
Old 06-21-2004, 09:45 PM   #9 (permalink)
TT Tuning
cams are off a 1/2 link. that dot on the cam gear should be under the yellow link. and the crank pointer should be on the yellow (2nd over from the left) timing mark on the crank pulley.
today i just fixed a jumped chain in my spair motor i've been running. i pulled the crank pulley,oil pumpdrive and crank seal to see the crankwas off a 1/2 link. Crapy thing was i took the tomei cams out because i thought their was too much lift so now im back to stock cams
Old 06-21-2004, 09:48 PM   #10 (permalink)
a real egg-head
i see that the dots are not under the cams, i now know that they are supposed to be. My only concern is that i think the cams will be too far advanced like that. Wouldnt that definately cause knock?
The dowel mark on the exhaust ispointing up as it sits right now, if anything it is a hair advanced... so wont another tooth that direction make it that much worse?
Old 06-21-2004, 09:52 PM   #11 (permalink)
TT Tuning
hit me up on aol afstegg
Old 06-21-2004, 10:16 PM   #12 (permalink)
sleeper
what afastegg said about the marks. The dots should be in the middle of the yellow links. So you're one roller off. (though the FSM says the marks are silver?)
Old 06-21-2004, 10:44 PM   #13 (permalink)
Give me fuel,give me fire
What is your ig. timing? If it skipped 1/2 tooth on the crank sprocket than the marks would be in the correct position. Did you just get the code 34 after the cam install? Your dowel pins are in the right position though.
The first thing i would do is check the ignition timing.
92 Sentra SER JDM mad tyte yo!
95 200sx SER purple somewhere on the side of the road in Arizona
Nismo_SR20 is offline   Reply With Quote
Old 06-22-2004, 01:45 AM   #14 (permalink)
Wiggatastic!
Could there be somerthing else setting off the knock sensor that is not acutally knock....like say, and exhuast leak or a rattling flex pipe/ cat.
Aztec Red 1994 Sentra SE-R.....
MARCUSMARC is offline   Reply With Quote
Old 06-22-2004, 06:56 AM   #15 (permalink)
a real egg-head
well when i check ignition timing, i unplugged the tps, started the car, revved above 3K 3times, then it wont go below like 1300 rpm, and the flashes are way off from all the marks.
When i plug the tps back in, and it idles, it reads 15 deg roughly
Old 06-22-2004, 10:00 AM   #16 (permalink)
Veritas
SERprise In WV's Avatar
Feedback Score: 17 reviews
From my point of view, your cam gears and chain look just peachy. If -and ONLY if- in those photos the crank pulley is sitting on top dead center and the distributor rotor is pointing to the 5 o'clock position (down and to the right as you look at it from the driver's side).
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: '93 SE-R with a VE
Old 06-22-2004, 02:32 PM   #17 (permalink)
just workin'
you need to remove the cam gears and rotate them each 1/2 link towards the front of the motor as long as the mark is on at the crank which you can't tell, is there any problem with your ignition timing when you have it back together,ie where is 15* close to the middle?
DnS Performance
Imported Auto Center, INC
96 g20 auto, stock
totaled200ser is offline   Reply With Quote
Old 06-22-2004, 02:47 PM   #18 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
No, from the pictures above, the cams are lined up. Just becasue the colored links don't line up, doesn't mean anything. Those are only helpful if you have the front cover off. If the motor is at TDC, and the exhaust dowel is at 12:00, and there are 20 pins between the dots on the gears, you are gravy.
The community is here.
Old 06-22-2004, 06:21 PM   #19 (permalink)
a real egg-head
ok guys heres the deal... the gold link is NOT underneath the dot on the crank
the first picture is a clear view for show purposes ONLY, just to illustrate whats going on down there.
the last pic shows the actual scenario, you can see the goldish part of the link.
Old 06-22-2004, 08:50 PM   #20 (permalink)
yeah, forget all the colored links, they are really only useful when assembling a new engine. like eric said, get the dowel pins at 10 and 12 for the intake and exhaust cams respectively, and make sure there are 20 links between and you are all set. just make sure the ignition timing is set correctly and reset your ecu to get rid of that CEL.
In silence man can most readiy preserve his integrity
1997 200SX SE-R Turbocharged
AZ WHITE SE-R is offline   Reply With Quote
