Old 06-21-2004, 07:48 PM   #1 (permalink)
Ga16de And Sr20de Motor Mounts
Are these motor mounts the same for both engines??
1988 NISSAN SENTRA E (SOLD)
1998 NISSAN SENTRA GXE (SOLD)
1998 NISSAN SENTRA SE So fresh & so clean!eek: (SOLD)
2005 TOYOTA COROLLA S ( I know )
SR20POWER1 is offline   Reply With Quote
Old 06-21-2004, 07:56 PM   #2 (permalink)
Tired Greasemonkey
Re: Ga16de And Sr20de Motor Mounts
i believe the dogbone is the same but tranny mount is different, i think both left and right mounts are different too, so basicly the torque mount is the only one you can use.
if i'm wrong someone correct me.
Old 06-22-2004, 08:19 AM   #3 (permalink)
Yes, it's a Sentra
sounds correct to me.... It's been a while.....
Alex
97 Sentra GLE (SR20DE swap)
01 Quest SE
97SENTRASER is offline   Reply With Quote
Old 06-22-2004, 11:31 AM   #4 (permalink)
Her 1st track day in 2017
Fosters's Avatar
Trader Rating: 41 (100%)
The actual mounts (the rubber w/ housing) between the GA and the SR are the same for the firewall, passenger side, and the dog-bone. It is the mount brackets that are diff't. If you are looking for a spare set of mounts (for ES or Prothane) you can get the GA's, and then just bolt them to the brackets. I can post the part numbers if you want.
Good luck,
Josh
'95 G20 - daily driver
'92 NX2000 - Money Pit
Izzy's Cages---------------Custom Steel---------------G Spec
Old 12-13-2007, 09:46 PM   #5 (permalink)
on the run
wait, so the inserts are whats the same? the housing is not. correct? i know this is an old thread but this is the closest ive found to my confusion... thanx.
Go fast.
'95 B13-- --for sale
'00 mustang-- --stock
''06 Corolla S-- --altis conversions
TopLevelB13 is offline   Reply With Quote
Old 12-13-2007, 09:46 PM   #6 (permalink)
on the run
anyone?
