Old 06-23-2004, 02:49 AM   #1 (permalink)
does taking out the EGR system gain anything?
i was just wondering if blocking off the egr system gain any hp...or does it loose hp??
and what is the benefit of blocking it if any?
200sx_TT is offline   Reply With Quote
Old 06-23-2004, 03:04 AM   #2 (permalink)
mhmmm
Re: does taking out the EGR system gain anything?
no you dont.... if u take it out you wont pass emissions but your car might run a bit better *** if egr is messed up, it messes up your idle and all this other crap lol but you wont gain hp or anything
Brian
-04 WRX
HawkINX4 is offline   Reply With Quote
Old 06-23-2004, 03:11 AM   #3 (permalink)
Coropate greed hater
After a long break, I'm finally going to say this:
SEARCH!
Damn, did that feel good!
-The Usual Suspects
Old 06-23-2004, 09:42 AM   #4 (permalink)
PLAY MY HEAD, MONKEY!
daveracer's Avatar
Trader Rating: 89 (100%)
it will clean up your engine bay a bit...
Old 06-23-2004, 12:52 PM   #5 (permalink)
The road's my slave
haha harris, i haben't seen you post "SEARCH!" in a while.
ChrisNX2000 is offline   Reply With Quote
Old 06-23-2004, 01:15 PM   #6 (permalink)
i did a search for EGR and 500 it show 500 thread, when i search for blocking EGR only two thread shown with no info on what im asking....so thats why i post...if you know the tread please search for it and post it for me, maybe im not using the right term.
as for emission, i just pass my smog check last week. Got two years to run my car. Not only that, my EGR is kind of old so i figure i take it out so it wont be used up and use it again when smog time comes around. Thats why i was wondering if it will affect my performance in anyway.....
Old 06-23-2004, 01:20 PM   #7 (permalink)
JDM BOOST WHORE
SR20 91 SE-R's Avatar
if someone can post pics of the egr crap removed with the block plates that will be cool because i removed the aiv crap but was not sure about the egr.
SR20 91 SE-R is offline   Reply With Quote
Old 06-23-2004, 04:04 PM   #8 (permalink)
Trader Rating: 102 (100%)
Yan try to track down a JDM manifold, it already has the EGR stuff eliminated. here's a comparison pic of the US and JDM manifolds
Old 06-23-2004, 04:20 PM   #9 (permalink)
I removed the EGR system on my 200 and the amount of vacuum hoses removed was worth it for me. I can't pass emisions anyway, so I didn't need the EGR, and it was part of my quest to solve my idle problems (still working on those). I did not notice any performance increase or decrease at all. If you still have to pass emisions I'd leave all that stuff alone.
webninja is offline   Reply With Quote
Old 06-23-2004, 04:28 PM   #10 (permalink)
JDM BOOST WHORE
thanks for that pic fast but i ment removed off a usdm engine
Old 06-23-2004, 06:47 PM   #11 (permalink)
i already wasted 10 bucks buying a header plug for my hotshot header and block off the egr hole to the throttle body, so if there is no loss of power, ill just leave it the way it is. Plus when i comes time to smog i have to put back my stock header anyway so i can change everything at once, its pretty simple..
one more question...do i need to plug anything else besides the header and the throttle hole??
Old 06-23-2004, 06:48 PM   #12 (permalink)
mhmmm
there is one between the 2nd and 3rd runner on the plenum.. you need a plate for that one too
Old 06-24-2004, 12:03 AM   #13 (permalink)
JDM BOOST WHORE
do you have the blockoff plates of yours brian?
Old 06-24-2004, 12:16 PM   #14 (permalink)
not my president
i have block off plates 15 bucks shipped you just need to get the shorter bolts
1992 nx2000:White: Sold
Danielle Wilson 2/10/07
Old 06-24-2004, 01:34 PM   #15 (permalink)
JDM BOOST WHORE
so all i do is remove the egr and put that plate over it? i wish some one have a pic so i can see exactly what to do.
Old 06-24-2004, 01:45 PM   #16 (permalink)
mhmmm
u gotta run hoses to diff places too.. dropped89 had the diagram.. i think i got it at home, but yeah im blocking off egr when i go turbo so when i need emissions i can go back to stock in no time
when i get home i will show you the diagram adam... it took me a while to figure it out but then when it hit me i was like wtf that was soo easy
under the TB there is this thing with like 3 or 4 nipples and those run to different spots.. i will tell you later when i get home, you have AIM i can just tell you there
Old 06-24-2004, 05:14 PM   #17 (permalink)
JDM BOOST WHORE
ok cool. whats your sn so because i dont have aol ne more, ill just use my friends sn. thank god for smog friendly places.
Old 06-24-2004, 05:21 PM   #18 (permalink)
mhmmm
mine is hawkinx4 lol
Old 06-27-2004, 07:39 AM   #19 (permalink)
POWER TO THE PEOPLE
Your car will feel 'peppy er'. Cause it won't have that laggy EGR sh*t on it. So slight you probably won't even notice it. An you might gain some HP by removing it.
Cause I dont' know how a US SR20DE makes 140hp and 133tq, but the JDM SR20DE (champange valve cover) makes 150hp and 133tq.
The only reason I can think of the power gain is because there is no restriction or less restriction, because of it having no EGR. I also removed my AIV stuff.
PARTS Wanted:: Drivers side Front and Rear doors, an a rear bumper cover for a P11. Just need door shells. My car was side swiped. PM me if you have this.
HiddenHands is offline   Reply With Quote
Old 06-27-2004, 11:23 AM   #20 (permalink)
not my president
http://www.sr20forum.com/showthread....847#post694847
pics in there
