Has anyone bought an aftermarket AC compressor and had success with it? My ac leaks right where that hose plugs in on the side of the compressor, don't know if its the compressor or the hose?
When you mean louder do you mean it makes a ticking noise? My compressor is loud too but once i'm moving the noise goes away. It could be a bearing, so i was told. It sounds real bad once you're inside the car. Let me know what your fix was.
It only gets loud when i stop. Once i'm in motion it goes away. I'm getting cold air but only if i'm goin over 30mph or so. In town sucks big time.
Sounds like you need to charge your system based on RPM's... someone else mentioned to me that you should hold RPM's up with one hand and charge the system with the other. You want the right pressure in the system for the RPM range you're driving in the most... obviously it'll still be cold in other RPM ranges still
kieran
95 200SX SE-R track car, 02 Maxima SE, 08 FX45, 08 G37
