Old 07-07-2004, 01:24 AM   #1 (permalink)
Soon to be G20 member....
Do I need to replace Head Bolts?
Blew my head gasket. An associate of mine advised that I need to replace my head bolts. Do I need replace the Head Bolt? Please advise.
Q in Sac
Team Driven NorCal
www.team-driven.net
No longer 1991 Nissan Sentra SE-R
Soon to be G20,
qinsac is offline   Reply With Quote
Old 07-07-2004, 01:45 AM   #2 (permalink)
No D E T.
Trader Rating: 18 (100%)
Re: Do I need to replace Head Bolts?
well, it depends, they can be re-used like once or so. the fsm indicates to check the length of the head bolt (since they are a stretch type) if that are shorter than 6.228" they are OK, if longer throw away and buy new ones. check from bottom of the head on the bolt to the end. use a 8" or 12" calipers (digital are easiest of course)
Jonathan Schultz
1997 200SX SE-R U13 Swap
2005 Toyota Avalon Limited
honkeybizkit is offline   Reply With Quote
