Old 07-07-2004, 09:03 AM   #1 (permalink)
Drinking The H Juice Now
BigB's Avatar
Fog Lights quit.. now the Cruise Con. is gone
My fog lights quit working a few months ago and i traced the source of the problem to the Bosch relay mounted to the firewall above the MC. now... my cruise control doesn't work and i was wondering if that relay also supplied power for the CC?
1992 SE-R WHT - SOLD
1992 SE-R BLK - R.I.P.
1999 Integra GS
1991 Integra LS -
BigB is offline   Reply With Quote
Old 07-07-2004, 10:03 AM   #2 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
Re: Fog Lights quit.. now the Cruise Con. is gone
2 Unrelated circuits. Make sure you didn't unplug the harness to the control box when you swapped the relay. Does the light in the switch come on? Does the cruise light in the gauge cluster light up?
1991 Sentra SE-R
The community is here.
Old 07-07-2004, 05:04 PM   #3 (permalink)
BigB's Avatar
have not switched the box yet for the lights... don't remember if light comes on or not.. i'll have to check on the way home from work tonight.
Old 07-07-2004, 06:27 PM   #4 (permalink)
Trader Rating: 102 (100%)
You should be able to hear a faint click sound from the relay when you turn the CC on and off. If you dont hear it, first make sure the switch is plugged in, then you might want to try and change that relay. Might even have a fuse for it somewhere.
Old 07-08-2004, 09:25 AM   #5 (permalink)
BigB's Avatar
alright... tried it last night:
1. both lights come on, at switch and in cluster
2. does not engage a speed when set button pushed
3. i do hear a click when switch on dash is pushed
any ideas?
Old 07-08-2004, 10:04 AM   #6 (permalink)
eric96ser's Avatar
any ideas?
Make sure the vaccum line from the vaccum box to the cable part is hooked up. Also check the cruise cable to make sure it doesn't have too much slack. It sounds like the cruise computer is working okay.
Old 07-08-2004, 02:50 PM   #7 (permalink)
BigB's Avatar
i wonder if slack is the issue as when it was working i had to go 5mph higher than whatever speed i wanted to set it on.
Old 07-08-2004, 03:07 PM   #8 (permalink)
eric96ser's Avatar
It could be. Make sure the adjustment nut hasn't backed out.
Old 07-10-2004, 02:36 PM   #9 (permalink)
SR20DE builder
sorry to jump in the thread but my cruise is doing the same thing....but there is no slack in the cable......I'll just keep my eyes on the thread and hopefully get some info....not trying to steal your thead..
Life is everything and nothing all at once
Jay
www.ilovetoargue.com
HATEnFATE is offline   Reply With Quote
Old 07-10-2004, 06:32 PM   #10 (permalink)
BigB's Avatar
checked today while washing/waxing the car.. looks like vacuum. the hose is cracking where it goes into the controller. anyone got a fix for this?
Old 07-11-2004, 11:37 AM   #11 (permalink)
eric96ser's Avatar
Its just normal vaccum hose, replace it.
