Old 07-08-2004, 10:42 AM   #1 (permalink)
NX2000 so long........
Best place to route relocated battery cables
What's the best way to route remote battery cables for relocating the battery behind the rear passenger seat in an NX?
nmartin is offline   Reply With Quote
Old 07-08-2004, 10:45 AM   #2 (permalink)
Re: Best place to route relocated battery cables
I'd imagine that you'd just run it through the firewall and then below your door sill covers to the back seat.
1991 Classic SE-R
2003 VW GTI 1.8t
"All that is necessary for the triumph of evil is that good men do nothing." - Edmund Burke
"A foolish consistency is the hobgoblin of little minds ... " - Ralph Waldo Emerson
2xSE-R is offline   Reply With Quote
Old 07-08-2004, 02:26 PM   #3 (permalink)
SE-R BUM
i can tell you what NOT to do... my buddy ran the battery cable under the car and drilled a hole in the trunk, battery was mounted down well in the trunk, it was clean and seemed a good ideal, but he did it on the right side where everyone else did and on the right side there is the exhaust pipe and muffler...which are very hot after a couple minute of driving. if you get the picture his wires melted and exposed the live wire and grounded his car. i was laughing so hard when he told me but luckly it just busted his main fuse!
(New all motor) 96 B14: Sr20VE JWT ECU, Msd switches, ES mounts and Bushings,2.25 stomung exhaust, KYB shocks, Eibach Sportlines, NGK Plugs/wires, ACT HDPP & Street disc, Hotshot CAI & Headers gen. 5,N-1 intake mani/TB,thermo spacers, B15 LSD trans, AEB1 GEN. 1 Header...
Old 07-08-2004, 02:32 PM   #4 (permalink)
fartin dust
There should be a plastic shield under the car on the driver's side for the brake lines. Just run it through there up to the motor.
I used to be a noob but now I'm just a dumbass
www.m4exhaust.com
james vick is offline   Reply With Quote
Old 07-08-2004, 03:45 PM   #5 (permalink)
not my president
run it the way you just said through the firewall under door sills
1992 nx2000:White: Sold
Danielle Wilson 2/10/07
Old 07-08-2004, 03:58 PM   #6 (permalink)
Any really good places in the firewall, that could be easily accessed and sealed?
I thought about running them underneath, but I was concerned about road trash, tire treads, abrasion, etc. It would be really nice to run them down a unibody frame tunnel or something close. I definitely won't strap them to the exhaust pipe.............
Old 07-08-2004, 04:27 PM   #7 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
I have done this twice now, I run it through the firewall below the AC box and along the center channel. It goes under the back seat and over the gas tank access panel. I then ran my RCA cables and stuff along the doors keeping them away from the power cable. That has worked great so far in preventing noise int he stereo.
Brent
Old 07-08-2004, 11:21 PM   #8 (permalink)
Brent
Did you use an existing hole our drill new one(s)? How did you seal it?
Old 07-08-2004, 11:30 PM   #9 (permalink)
Tired!
coach's Avatar
I used the hole that is there for the drain for the AC box. But, you could easily drill a hole with a stepper bit and use a grommet to seal it shut.
Brent
Old 07-09-2004, 09:23 AM   #10 (permalink)
Some people use the hole that your speedo cable goes through.
Old 07-09-2004, 03:39 PM   #11 (permalink)
shift_boost
Look under the dash all the way to the left there is a big grommet you can run oawg through. It comes out above the wheel in the inner splash shield.
myspace
95 chevy dually big, black, low, and diesel
twisted200ser is offline   Reply With Quote
