Old 07-09-2004, 12:00 AM   #1 (permalink)
Owned by Maximas!
What does your VOLT gauge read?
Like the title reads:
a) what does your VOLT gauge read
b) where did you connect it to (battery, cigarette lighter, alternator)
Just curious. Mine is connected to the battery and it points between 12V and 13v (leaning more towards 13).
akapaul is offline   Reply With Quote
Old 07-09-2004, 03:59 AM   #2 (permalink)
SE-R GREEK
Re: What does your VOLT gauge read?
Well, mine was stock (1992 Sunny 2.0GTi, N/A SR20DE, N14 chassis).
When engine is OFF it shows just below 12. When idling it shows close to 14. Faster revs, 14.5 or something.
Chris
Old 07-09-2004, 07:03 AM   #3 (permalink)
a fully charged battery is 12.65 volts.
Mark
95 se-r, avenir, HS fmic piping, spearco ic, calum realtime ecu, 3" jgy dp, 3" inlet magnaflow with 2 2.5" outlets out front each rear tire, walbro, nismo fpr, summint fpg, 2 10" pusher fans, koyo radiator, ats comp lites wrapped in azenis, on tein basics w/ pillowballs up front. Now featuring a gt2871r on JGY mani, and S3 cams!
ser_smokes_alot is offline   Reply With Quote
Old 07-09-2004, 10:55 AM   #4 (permalink)
'93 SE-R, Hawker G13-EP(11 lb.)
MDM-100 displays:
Cold engine in the morning, key on, engine off = 12.0 V
Cold start in the morning, at idle = 14.4 V
After 30 minutes of driving, at idle = 13.6 - 13.7 V
After 30 minutes of driving, key on, engine off = 12.2 - 12.5 V
jp314 is offline   Reply With Quote
Old 07-09-2004, 11:19 AM   #5 (permalink)
wait...i have a honda?
NismoSER's Avatar
Trader Rating: 17 (100%)
'91 SE-R, Hawker G13-EP(11 lb.)
S-AFC-2 displays:
Cold engine in the morning, key on, engine off = 12.2 V
Apex-i Turbo Timer
Cold start in the morning, at idle = 13.8 V
After 30 minutes of driving, at idle = 13.2 V -13.8 V
Chris
'91 VVL-powered SE-RSOLD
'04 G35 6MT
'99 CBR600 F4
Old 07-12-2004, 05:33 AM   #6 (permalink)
SE-R GREEK
Last two posts were prime examples of HOW one should answer a question psoted and CONTRIBUTE usefulll info to the forum.
Lat post was a prime example on how much attention we should be paying to any gauge we have in our car.
2 gauges, both by APEXi (one reputable company), both reading what the ECU reads (the same value) AFTER the sensors have translated the actual measured physical parameter (battery voltage) in ONE voltage.
Cold start in the morning at idle is shown with a .6V difference!!!! This is close to 5%!!!
Chris
Old 07-12-2004, 09:02 AM   #7 (permalink)
NismoSER's Avatar
I always found that pretty weird, that there was such a difference. I wonder if anyone else has that issue...
Old 07-12-2004, 11:29 AM   #8 (permalink)
well i was sayin if he's using a gauge with a needle on it then if its pointing between 12-13 but closer to 13 would be saying his battery is fully charged. now i can also tell you that with my hks type1 i also get voltages very similar/same as above.
i take my voltage from the ignition switch after the ecu
