Old 07-09-2004, 02:12 PM   #1 (permalink)
PROJECT NX2K TURBOOOO
Overheating Problem
I was driving yesterday and my upper radiator hose blew out. The whole time I was driving which wasnt long, I had the heat on high and it was blowing cold air and the temp gauge just keep rising. I had checked the temp before of the rad with a temp probe and it didnt go over 200 degrees. Im wondering if this is my heater core?
93 NX2000 with U13 BB, GTIR T28, 444cc injectors, JWT programmed ECU - 3 Bar, Cobra MAF, 3 inch dp, Nismo FPR, greddy type s bov, spearco intercooler, gsx turbo intake, fidanza flywheel, Clutchnet Clutch, UR Pullies, Place Racing Motor mounts and DogBone mount, Pace setter short throw, walbro pump, outlaw engineering, ES control arm bushings, trunk mounted battery.
NissanPower305 is offline   Reply With Quote
Old 07-09-2004, 02:17 PM   #2 (permalink)
owned by SE-Rs!
Re: Overheating Problem
Blew out as in it just came off. Or did it actually wind up with a hole in it?
Subculture is offline   Reply With Quote
Old 07-09-2004, 02:27 PM   #3 (permalink)
the hose blew apart like there was too much pressure going thru it and also my reservoir tank was very close to the top maybe an inch or two below the top.
Old 07-09-2004, 05:23 PM   #4 (permalink)
Tired Greasemonkey
could be
1. bad t-stat stuck shut causing high psi
2. bad water pump
3. bad radiator/cold spots
4. could be the heater core?
Old 07-09-2004, 05:30 PM   #5 (permalink)
tsat is new and ran it w/o a thermostat
water pump is new
swapped radiators and no change
bypassing the heater core today and ill post results thanx for your help
Old 07-09-2004, 05:44 PM   #6 (permalink)
SPEC V'in It....
i have the same problem and mine is the water pump and the a/c compressor
YES SER is offline   Reply With Quote
Old 07-10-2004, 03:44 AM   #7 (permalink)
owned by SE-Rs!
water pump is new
Well for starters, you'll want to install the thermostat. Your engine will never reach proper operating temps without it.
Also, bypassing the heater core will make you motor run hotter. ask me how I know.
I say you should replace you radiator and heater hoses. You radiator hose might have been just old.
Also, if you temp sending units, ECU and Temp gage, are old, replace them too.
When the OEM temp sending units get old they can read colder than the engine is actually running.Ask me how I know.
Old 07-10-2004, 05:36 PM   #8 (permalink)
this link shows what I have already done.
http://www.sr20forum.com/sr20de-technical-corner/82290-overheating-problem.html
