Old 07-11-2004, 04:10 PM   #1 (permalink)
pressing in motor mounts
I just bought some prothan motor mounts. Everyone keeps saying you have to go get them pressed in at a shop. Some have used there cars to do this.
Now, I havnt installed mine yet, but I had an old mount (the mount thats most forward on the car, on the crossmember). I havnt tried this on the other mounts, but what I did seems so much easier then what everyone else is doing.
Getting the old rubber out: I drilled some holes in the rubber to free up some space for it to flex then hit it with a hammer. The larger piece of rubber was deteriated and just fell right out. Took me about two minutes tops.
Installing the new mounts: First I took the metal pins out so the rubber had more room to flex. From doing that, I got the smaller piece of rubber in by hand. For the larger piece, I first sprayed some wd40 on it. Next, I put the new prothane mount and the old motor mount in a vice with a piece of wood on the new mount to protect it. Then I just tightened up the vice. It went right in. I had to readjust where it was in the vice a couple times to get it to go in real good. Once the new mount was coming out the other side and in contact with the vice, I took it out, put the wood on top of the mount, and gave it a few blows with a hammer. I just supported the mount on each end on the open vice so nothing was touching the bottom of the new mount so it could slide in unobstructed. It went right in. Total time on that was no more then 5 minutes.
Hope that helps.
-Mike
Old 07-11-2004, 04:13 PM   #2 (permalink)
Re: pressing in motor mounts
ya thats prettymuch how i put my es inserts in too, i know they're a little easier to get in than the prothanes but that method works pretty well.
'94 Classic SE-R with new SR20DE, rebuilt tranny, Fidanza flywheel, ES inserts and shifter bushings.
greg5286 is offline   Reply With Quote
Old 07-11-2004, 05:04 PM   #3 (permalink)
Her 1st track day in 2017
Fosters's Avatar
Trader Rating: 41 (100%)
The dogbone is the easiest to do. The others are a little more difficult, but your method should work on them. The only one you might have a problem with w/ that method is the front (passenger side) as it has a metal "collar" that has to come out also, but a sawzall can fix that.
Josh
'95 G20 - daily driver
'92 NX2000 - Money Pit
Izzy's Cages---------------Custom Steel---------------G Spec
Old 07-11-2004, 05:43 PM   #4 (permalink)
My Ass, your face
vladha's Avatar
The dogbone mount is very easy to do. The one that was the biggest pain to get in was the firewall mount. The rubber just didn't want to go in. Took me like a total of 15 minutes, max, to squeeze in the other 3... the last one took me 2 hours. No vise and no press available.
Peace,
Mark
vladha is offline   Reply With Quote
Old 07-11-2004, 05:46 PM   #5 (permalink)
/// God Speed! ///
A vice will def. work. I did all my ES Motor Mount inserts with a vice.
The pass. side mount is a little tough but if you use the right tools to cut the sleeve and the chisel or hammer it out, it is a piece of cake to install the ES insert.
Darren
E-Mail: Its311Pete@alltel.net
9.277 in 1/8 2.023 60ft
91 Classic w/ a few bolt ons.
http://img.photobucket.com/albums/v3...wse-rsmall.jpg
Its311Pete is offline   Reply With Quote
Old 07-11-2004, 06:11 PM   #6 (permalink)
Honda Employee...
I haven't had to get any of my bushings or mounts pressed in or out because of bench vises, wd40 and KY. They've been good to me. I'm not kidding aboutthe KY either
-Zack
-'91 SE-R, Aztec Red: JWT Pop-Charger, Fidanza Flywheel, JWT PP w/01 SE disc. AGXs w/GC coilovers (300/279) & C/C plates. NX2K Brakes w/Carbotech pads & Crown SS lines. Progress rear sway bar. Active Tuning RSTB, ES Bushings & motor mounts.
gottabfast is offline   Reply With Quote
Old 07-11-2004, 06:23 PM   #7 (permalink)
wait...i have a honda?
NismoSER's Avatar
Trader Rating: 17 (100%)
The dogbone is real easy. I did one once by jumping onto it, lol. The 3 other times though, I used the car method. I don' have a vice or a press either.
Chris
'91 VVL-powered SE-RSOLD
'04 G35 6MT
'99 CBR600 F4
Old 07-11-2004, 06:39 PM   #8 (permalink)
PLAY MY HEAD, MONKEY!
daveracer's Avatar
Trader Rating: 89 (100%)
i used my rear tire on my ford focus as a press to do them all. didn't take long and was effective.
Old 07-11-2004, 06:42 PM   #9 (permalink)
EJ25 AWD Monster
Trader Rating: 26 (100%)
WD-40 or an oil will also help them slide in better.
Brian.......
2005 Subie LGT....new toy 14.2@96 stock. 12.95@106.6.......1.80-60' rocks
2007 Forester XT AUTO-12.97@104.29
@008 Suzuki Blvd, the cruiser
1964 1/2 mustang coupe, 289 auto For Sale!!!!!!!
TUNED200 is offline   Reply With Quote
