hey guys....recently i installed a new B&G coilover suspension on my b14, shortly after, my wheel bearings on the front left driver side went out....fair enough, i went to the junk yard and bought a hub and installed it..everything seemed fine for a couple of days until later i heard the noise coming back, i checked and sure enough, the bearings went out again on the drivers side of the car. It might be coincidential but my friend has a b13 and his bearings keep going out on his passenger side(hes replaced them like 3 times)...he has ground controls(stock struts). I really dont know what the problem is or why these bearings keep going out, does anyone know what can make them go out?
are you getting used hubs? I would reccomend getting new bearings pressed into the hub.
My real name is Kyle
Have you been having the same shop press the bearings in??? If so, go to a different shop. If you don't press them in exactly straight, they can be F-d up.
Matthew Kogan
#42/142 STS
91 SE-R Lot's of Goodies
well, i used a hub from the junk yard....the whole assembly.. it was off a b13 but that shouldnt matter. i dont wanna spend the money it cost to buy new oem bearings(expensive as a mofo) only to find out that they will go out in another week or two...
Just for clarity, you aren't replacing the bearing? Just buying a new (to you) spindle and hub, and then installing it? You need to get a new bearing ($50 w/ seals) for a spindle, get it pressed in, and have the machine shop check the hubs (piece w/ lug nuts). If the hub is bad, the new bearing will just be shot after that. Try this, and see how it works.
Make sure that whatever shop is doing the works uses a micrometer to measure the hub/spindle's shaft thickness and that it is in spec, personally if the shop dies not automatically do this in front of me I wouldn't do buisness with them, the bearing is a press fit and must seat tightly and squarely so make sure that the hib/spindle shaft is within spec, a shop will take your money if u just go tell them to press a bearing on but u need to make sure that hib/spindle is within spec.
