Re: caliper pin bushings
it's just a rubber sleeve that needs to be air tight and should have some high temp grease in both top and bottom
did mines weekend and what a good job i did if i do say so myself
u should also clean and put some light grease on the rattle clips so that the pads slides easily
u may need an entire repair kit for this sleeve however
Dave
