Quick Help: Bell Housing Bolt Size? - SR20 Forum
Old 09-17-2004, 11:17 AM   #1 (permalink)
My SR's are Multiplying!
What diameter and thread pitch are the bolts that hold the transmission to the engine... I think they are M10x1.5, but not sure. I already searched.
I am taking an engine over to a friends house and helping him put it in an engine stand and I need to buy some bolts on my way over there. This would help out to know what size bolts I need.
THANKS!!
compression is offline   Reply With Quote
Old 09-17-2004, 01:51 PM   #2 (permalink)
Nitelife's Avatar
Feedback Score: 46 reviews
http://www.sr20forum.com/showthread....anny+bolt+size
12x1.75
I got 90mm to hold the engine on a stand; I beleive the stock bolts are 75mm in length
Old 01-08-2012, 09:02 PM   #3 (permalink)
Hi everyone I have a SR20ve and I want to make it turbo. I have a T28R already and I would like 2 make 350hp to the wheels. I know that I have to change the piston 2 a lower compression piston. So I read that using SR20det piston R good 4 the job. My block is already tap and ready 2 go. So what I am asking is there anything I am missing?
BlueBirdKid is offline   Reply With Quote
Old 01-11-2012, 01:12 PM   #4 (permalink)
Drivin' my life away. . .
Start a new thread. No one will find your question under this thread. Put it in the VE section.
"If everything seems under control, you're just not going fast enough." - Mario Andretti
Old guy is offline   Reply With Quote
