Old 09-19-2004, 03:04 PM   #1 (permalink)
"shift_happens"
Trader Rating: -1 (0%)
Carbon Cansiter question?
I need to know where the vacum line that comes out of the bottom of the carbon canister goes on a 1991 nissan sentra se-r. Mine looks like it was pinched/ worn through/ or cut by something. Also the is a ground wire, grounded to the frame right next the carbon canister that also looks as if it was cut, Im not sure what this is a ground for and where it goes. any comments or help is greatly appreciated......
91 sentra se-r,sr20de, p&p head, balanced internals, 2.5" catback, unorthodox pulley set, fidanza flywheel, short throw, strut tower brace, HS CAI, aftermarket mounts, nx2000 brake upgrade, weaponR header, ebay steering wheel, minor weight reduction...
james_se-r is offline   Reply With Quote
Old 09-20-2004, 12:35 AM   #2 (permalink)
little Thunder
nismo91's Avatar
All three lines from the canister plugs under the throttle body.
This is the ground for the tranny. Look at your tranny right on top of the driver side axle.
Also there is a ground wire, grounded to the frame right next the carbon canister that also looks as if it was cut, Im not sure what this is a ground for and where it goes. any comments or help is greatly appreciated......
= Steve Lotho =
= = 91 Classic = =
= = Forum Rules = =
nismo91 is offline   Reply With Quote
Old 09-20-2004, 05:54 PM   #3 (permalink)
"shift_happens"
what do you mean by plugs under the throttle body? There is only one line that come out of the bottom of the canister, does it plug into the throttle body??? Hope I dont have my vacume lines crossed up???
Old 09-20-2004, 06:15 PM   #4 (permalink)
PLAY MY HEAD, MONKEY!
daveracer's Avatar
Trader Rating: 89 (100%)
The ground wire, specifically is for the starter i beleive (since the starter grounds to itself...).
Old 09-20-2004, 06:16 PM   #5 (permalink)
Technician @ Toyota
scortch99th's Avatar
My carbon canister's lower hose is connected to nothing.
It is sord of like a vent.
Old 09-20-2004, 09:49 PM   #6 (permalink)
No, Steve's right. During my engine swap last week I noticed the same wire just hanging around and sure enough just as Steve had hold me there was a connector on my tranny with a wire missing from it.
Paul
1992 Sentra SE-R
1992 240SX HB
1993 Sentra SE-R (Sold)
1992 Sentra XE (Sold)
B13SentraXE is offline   Reply With Quote
Old 09-20-2004, 09:52 PM   #7 (permalink)
daveracer's Avatar
Yes i know...since the starter grounds to itself, and gets bolted to the tranny...i beleive that wire grounds the transmission for the starter.
Old 09-20-2004, 10:06 PM   #8 (permalink)
"shift_happens"
thanks on the ground wire question. but Im still stumped on the canister thing. I cant see anything near it that it looks like it plugs into, is it suppose to be a vent like scortch99th said?
Old 09-20-2004, 10:55 PM   #9 (permalink)
Nitelife's Avatar
I know one of the hoses went to a vacuum plug down below the brake booster on my 92 SER. The others went to the manifold like nismo said.
