Old 09-19-2004, 06:05 PM   #1 (permalink)
"shift_happens"
Trader Rating: -1 (0%)
HELP! Idle speed adjustment screw
New engine, idles @ right below 2000 rpm, needs to be right below 1000 rpm.....
I cant find the Idle speed adjustmet screw on my 1991 nissan sentra se-r.
I think my timing is off as well but i cant adjust that until i get it to idle correctly..........any suggestons???
as far as I know i dont have any vacume leaks, and I believe my EGR valve is working properly........
91 sentra se-r,sr20de, p&p head, balanced internals, 2.5" catback, unorthodox pulley set, fidanza flywheel, short throw, strut tower brace, HS CAI, aftermarket mounts, nx2000 brake upgrade, weaponR header, ebay steering wheel, minor weight reduction...
james_se-r is offline   Reply With Quote
Old 09-19-2004, 08:13 PM   #2 (permalink)
The screw is on the passenger side (left side if you are looking at the motor) of the manifold, it's to the left of the oil filter. You'll need a flat head screw driver to adjust it.
Paul
1992 Sentra SE-R
1992 240SX HB
1993 Sentra SE-R (Sold)
1992 Sentra XE (Sold)
B13SentraXE is offline   Reply With Quote
Old 09-19-2004, 10:46 PM   #3 (permalink)
315LB CLUB [][]-----[][]
theres a better right up about it in the tech. library....but yeah just find the screw by your oil filter and yer set.
'99 Sentra SE-L
'91 Sentra SE-R sold
FloridaSR20s
Thomas
sr20sentra91 is offline   Reply With Quote
Old 09-19-2004, 10:47 PM   #4 (permalink)
JordanWhiteMusic.com
Here is my best guess from memory:
1) Stand in front of the engine with the hood open
2) Put your left hand on the upper LEFT corner of the valve cover (closest to passenger side-view mirror)
3) Move your hand back about 4 inches towards the windshield, then move it about 2 inches to your left - it should be right around there, it may be plastic looking but since you have a B13 probably not.
Jordan - '94 Sentra LE
'07 Honda Fit Sport
www.myspace.com/jordanwhite
Storm88000 is offline   Reply With Quote
Old 09-19-2004, 11:25 PM   #5 (permalink)
"shift_happens"
thanks guys atleast now I know where it is so i can ajust it after i get my other problems worked out....
