just wanted to know if the DE rings, rod, and main bearings will work in DET? Also has anyone put a set of standard bearings in thier bottom end?
The rod and main bearings are interchangeable between the DE and DET, just make sure you get the right thickness.
I am running standard DE bearings in my S13 DET.
