Old 09-20-2004, 06:49 PM   #1 (permalink)
Nos Slut
Wont go into Timing Mode - Something just clicks, clicks
When I unplug the tps the engine revs up to like 2,000rpm and something on the engine goes click, click, click??? Its always worked fine before?? Ive tried using the help me faq's with no help...
anyone
95 200sx SER
PS Header w/ 2.5" Collecter| 3" Intake w/ POP| 2.5" Exhaust w/ Cherry Bomb Pro muffler| ES Bushings| NX2000 Sway Bar| 91 Intake Cam| G20 Ecu
96 Sentra 1.6(B13)
Lightend stock flywheel| ACT HD PP w/stock disc| UR Crank+PS Pulley| 3" Intake w/ K&N Cone| XS Power Header| ES Bushings| ST Sway Bars| 2" Exhaust w/ Magnaflow Muffler| 60mm TB| Intrax Springs| 50hp Shot NOS
HaulinSentra is offline   Reply With Quote
Old 09-21-2004, 01:41 AM   #2 (permalink)
Have you checked if any of the spark plug wires are loose on the distributor? I think that might be it, hope this helps.
Phxdude is offline   Reply With Quote
Old 09-21-2004, 03:05 AM   #3 (permalink)
oh so LAZY
Will's Avatar
the rpms rise on thier own when you unplug the tps? hmm....
Click for My Car Pics
White '92 NX2000 All Stock.
Will is offline   Reply With Quote
Old 09-21-2004, 06:35 PM   #4 (permalink)
Nos Slut
It just revs up from idle to about 2,000. You can hear something on the passanger side of the engine go: click, click, click (LOUD), for about 10 seconds then just statys reving @ 2,000.
Also while that thing is clicking , it sounds like the maf is cutting in and out. it makes that sucktion noise.
what the hell is going on..
Old 10-04-2004, 10:45 PM   #5 (permalink)
Swap Guru
sounds like a huge vacume leak.. my engine did that when i did a swap when i disconnected the TPS and i found a huge vacume leak.. fixed it and no longer does it..
Red200Se-R is offline   Reply With Quote
